Question about Toshiba e800 Pocket PC
Internet access via bluetooth
How can connect my toshiba PPC e800 to internet with bluetooth using my desktop pc attached with a usb bluetooth adaptor and connecting to internet with an ADSL connection
    Master:
  • 903 Answers
I don't have a PDA, but I'm working much with Bluetooth in my Toshiba Notebook. So I found a interesting link from Toshiba about Bluetooth. Perhaps it helps you! http://aps.toshiba-tro.de/bluetooth/
Posted on Sep 08, 2005
My Dell Inspiron 560 suddenly stopped connecting to internet through cable-modem.
Onboard adaptor hardware failure? Or is it missing Drivers?
Wireless adaptor - did you install drivers for adaptor? Did you check that WiFi on the adaptor is switched on?
On a side note: I've found that USB 2.0 Wireless N adaptors are the best for connectivity, as they have their drivers on the adaptor, are fully plug and play (Vista/7/8 and even some models on XP). I recommend Transcend (brand name).
Nov 28, 2011 | Dell Inspiron 560 (Intel Pentium Dual Core...
Tip
How to use a mobile phone as modem.
Two methods are there to use your phone as modem
1)you can use your PC suit to use your phone as modem for You need
*USB cable or Bluetooth on your mobile
*PC suit software provide by phone manufacturer(ex:Nokia,Samsung,LG,Sony Ericsson).
To use your phone as modem
*install the PC suit softwareConnect your phone to PC via USB cable(I recommend you to use USB because it's faster)
*Open PC suit and select "Connect to internet"
*if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list now it works.
2)You can use Bluetooth technology to connect to internet (2 methods are there)
For this you need
*Bluetooth on your PC and phone
To connect(in windows OS)
*Click on Bluetooth symbol on task bar
*Select add device select from device which can be connected to your PC list(set your Bluetooth device to visible all mode)
*Add your device to your PC Add completion of the above...
*Again click on Bluetooth symbol on task bar
*Select "show all devices"
*now select your device(one click) at this time 4 options appears on top your devices list
*select connect using>access point
and 2nd method is
*Again click on bluetooth symbol on task bar
*Select "show all devices" *double click on your device
*select connect to internet from the dialog box which appears after selecting the your device
Above options are with respect to Window 7 and Windows related operating system.
Thank you...:)
ANY SUGGESTIONS?
on Jan 30, 2011 | Computers & Internet
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
What is Bluetooth Dongle?
Hi message4,
Welcome to FixYa! How are you doing?
Bluetooth Dongle is often refer to USB Bluetooth Adapter, it is a device which you connect to your computer via USB port to allow data transfer from your PC or Laptop to Car Kits, Mobile Phones, PDAs, GPS Receivers and much more.
Hope that helps. Thank you for using FixYa.
May 01, 2011 | Acer Aspire™ T180 PC Desktop
Connect to internet?
This answer assumes that the reader is already using their SD slot and wish to use another way to connect to the internet. I'm going to show you how to connect a USB Bluetooth dongle using the Toshiba e350 USB host cable. After that you can choose to share a computer internet connection via ActiveSync/WMDC or use BT DUN and a wireless phone with existing internet plan.
Windows based PC software (only needed for ActiveSync based internet sharing):
ActiveSync or WMDC
Toshiba PC Bluetooth stack 7.10.04 (or latest version for your operating system, I'm using Windows 7)
PC Hardware:
Super Mini Bluetooth 2.0 Adapter Dongle (mine was VID 0A12 PID 0001 Broadcom BCM2045 "CSR" based)
WM2003 PPC software:
Zeno USB Host Drivers v6.0a
Toshiba PDA Bluetooth stack 4.01 (filename bltstk-401-en.zip)
WM2003 registry editor (TaskMgrv2.9_WM2003SE.zip is a free task manager and registry editor, very cool)
Opera Mobile 8.65 (optional)
WM2003 PPC Hardware:
Toshiba USB host cable
2 or 4Gig SD card (for e350)
I'm going to target a Windows 7 PC with USB Bluetooth adapter, Windows Mobile Device Cener (WMDC), and an already partnered and synced Toshiba e350/355. The reader should already have a 2Gig SD card in the e350; remember WM2003 doesn't support SDHC. Any software to be installed onto the device should be done through ActiveSync Add/Remove and should not be installed to the default internal memory, but instead to the SD card.
Let's start by loading the e350 software. Install the Zeno Host drivers, followed by the Toshiba 4.01 stack. There is a newer version of this stack but it didn't work for me, so find the older bltstk-401-en.zip. The registry editor is needed for ActiveSync internet connection sharing but optional for BlueTooth Dial-up Networking (BT DUN). I'd recommend installing Opera Mobile as well. Be sure to press the reset button on the back of the e350 when done. You may now connect the USB host cable with Bluetooth adapter.
On the Windows PC connect your Bluetooth adapter and install the Toshiba PC bluetooth stack. Power up the e350 and, after a short time, there should be a wireless icon in the lower right hand corner of the main window. Back to the Windows PC, double click the Bluetooth icon in the task tray and you should be prompted to create a new connection. After awhile it should recognize your Pocket PC. If at any time you are prompted to insert a password for secure connectivity, write down a number (preferably 8 or more digits) and type it in. It will probably ask on the Windows PC first but once you continue immediately check your e350 since it will now prompt for the same password. Once it has been entered in both devices they are now "paired".
Tap the wireless icon on Pocket PC then Bluetooth Settings. Tap the magnifying glass to search for connections, your PC should already be listed as a remote device. Tap and hold over the name of your PC in the upper portion of the window and select Update Service. At least one COM port should be listed in the lower window. Tap and hold over it's name, then tap connection registration.
On the Windows PC open WMDC and select Connection Settings. Change the "Allow connections to one of the following:" drop down to the COM port listed on your device and be sure it's checked. The other settings should be default.
On the Pocket PC tap ok to close Bluetooth settings then tap Start > Programs > Bluetooth Folder > Bluetooth Connection. This will initiate an ActiveSync session and, if everything has gone well, it should connect, perform a sync then immediately disconnect. I have a problem with the immediately disconnect part, that's where the registry editor comes in. Using your preferred registry editor locate the HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\Bluetooth\DeviceProperty\Mode\ActiveSync\AutoDisconnect key. It's default value shoule be 1 but we want to change it to 0 thereby preventing ActiveSync from disconnecting after it sucessfully syncs.
With that done you'll probably need to reset the e350 again. At this point, because ActiveSync is set to share the computer internet connection by default, the next time you connect you should have internet access. Open your preferred web browser and check. When you are done with the internet, tap Start > ActiveSync and the Stop button. In Windows 7 as long as I'm connected I can see the Pocket PC in Windows Explorer as if it were an external drive. This makes it very easy to copy files back and forth wirelessly. Initially I set up a bridged PAN connection but, to be honest, ActiveSync works much better all around.
For BT DUN you'll need a properly configured and enabled Cell Phone with bluetooth DUN capabilities. Simply make the phone "visible" and search for it as you did the Windows PC. Pair with the phone, Update Service and register Dial-Up Networking. Tap Start > Settings > Connections tab > Connections > Add a new modem connection (Tasks tab). Enter a name for the connection and choose Bluetooth Card as the modem, then set the dial-up number, User Name, and Password from your Cell Provider. On the Advanced tab (next to Tasks tab) you may want to tap Select Networks to verify "Programs that automatically connect to the Internet should connect using:" My ISP.
You can set up ActiveSync Internet sharing along side BT DUN. When ActiveSync is connected it will automatically be the source internet connection. When disconnected, the e350 will automatically attempt to use the BT DUN connection instead.
Why not use the default Microsoft BT stack on the PC? It doesn't publish any real services, just a COM port that I never got to work. The Toshiba BT stack does have a 30 day warning so you might need to fix that.
For me the total cost of setup was about $30. The host cable was $15, the SD card $10, and the USB BT dongles were $2 apiece.
Nov 03, 2009 | Toshiba e350 Pocket PC
SGH-E250 internet access via data cable or blue tooth to PC
You have to buy a data cable or use bluetooth.Create a dialer which dials *99# using your samsung modem over bluetooth
Dec 11, 2008 | O2 Samsung SGH-E250 Cellular Phone
Wii USB Adaptor
the easiest thing to do is to get an usb wireless adapter for about 30 bucks , connect it to your pc or laptop , set it as an access point , then just use the built in wifi on the wii , to get on the net, hopes this works , did for me
Oct 30, 2008 | Computers & Internet
Pocket pc 3850
Set it up with what? Do you mean sync with your computer? Are you using USB or Bluetooth?
Best thing to do.
1. Unplug your USB connection from PPC -> Computer
2. Uninstall Activesync if you have it installed
3. Restart your computer
4. Re-install activesync
5. Restart your PPC
6. When asked to connect the PPC connect it via USB
Jan 06, 2008 | Compaq iPAQ H3850 Pocket PC
WM 2003 SE update error ???
I had the same problem with mine e800. But after many of attempts I was able to make an update. Problem was connection between notebook and PDA. Check connection settings and try it again. It must work.
Sep 08, 2005 | Toshiba e800 Pocket PC
E-125 and Cradle/Internet access......
I don't know about the craddle - but I guess it should work too. I use a USB cable - and it works okay. You need to run MS ActiveSync (install v. 3.5 - it's better), and when you see a green circle in your taskbar, you can try and access Internet (your desktop should, of course, be connected to Internet).
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Toshiba e800 Pocket PC Logo
144 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
