Question about Samsung HP-S5053 Television
I have pixels running horizontal accross the screen.
It started with a small line of white (snowy) line at the top, Gradually more and more are coming and there are other colors. When I bring up the menu, where the menu is on the screen the pixels go away for a short time then come back. This tv is a little over a year old and warrenty is over. I have tried everything in the menu to change this. We have high speed cable if that matters. If you have any help please be specific and simple.
  • 1 more comment
  • mccallum Aug 28, 2008
    My son and I removed the back reseated the cables and connectors and replaced the back. When we turned on the tv half of the problem was gone. What do you suggest?
    Actually now the same amount of snow/pixel problem came back now.
  • Cadet Zemm Mar 28, 2009
    I have the same problem. I had a repair guy come take a look at it and he spent some time on the phone with Samsung and they determined the problem is in the main board which will cost about 500 bucks to order and have them replace (300 for the part, 200 for the labor).
    It looks like the part is just a card that gets plugged in like a board in a computer so I plan on just doing it myself if I need to order anything. I'm gonna try reseating connections when I get home today. I'm curious if the original poster ever got this resolved or not though? thank you.
  • 4,234 Answers
What you are seeing is noise on the digital line or through the connections to the panel. This is usually only a connection issue. Carefully remove the back and reseat all of the cables and connectors. That should resolve the problem. If not, update this and we'll look elsewhere.
Dan
Posted on Aug 28, 2008
  • ABRsvcs Aug 28, 2008
    What problem remains?
    Dan
    I have a feeling that this is a heat related problem. If you can solder, pull each board and check the solder connections resoldering any that appear grainy. Other than that, all that can be done is to run the unit without the cover and use a freeze spray to locate the offending part(s).
    Dan
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
My phillips 2006 hd tv has a black line across the screen with a snowy freeze
If you have parallel horizontal black lines on a white background, you can see the separation between the lines when it is viewed at close range (Figure 1). As you view the lines from further and further away,the image gets smaller, you eventually get to the point where you can no longer see the separation between the lines, and it looks like one line. Losing the ability to see separation in the lines is exactly what happens when you sit too far back from an HDTV set. If we apply the same principle to an HDTV, a 1080p resolution HDTV has to fit 1920 vertical and 1080 and horizontal black lines separated by the white space on the screen, (that is the pixel grid of a 1080p HDTV display). Furthermore the spaces between each cell of the grid need to be very small in relation to the area each cell occupies, or you will get a screen door type effect. A bigger HDTV can increase the size of the cells and the separation between the cells, so everything doesn't run together when you sit further back.
Performance chip
May 22, 2012 | Philips Televison & Video
I have an LG 42'' PDP42V60001 plasma TV it has a white line running from top to bottom covering around a 1/4 of the screen, it moves accross the screen and the rest of the screen is black. Intermittently...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 17, 2017 | LG Televison & Video
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
My picture shrinks
resolder the vertical deflection i.c. also replace elecrolytic capacitor in the vertical circuit.
Sep 28, 2009 | Hitachi 50UX57B 50" Rear Projection...
Horizontal Lines on a LN-S3241D
i'm sorry to say It's most likely broken. I think the LCD screen is going. Try calling up Samsung to see if they can fix it or repair it for cheap. Good Luck.
Aug 29, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
Syncmaster 245B Monitor Shivering horizontal lines
Which type of video connector are you using? VGA or DVI?
If you are using VGA, the horizontal line could be due to interference, like from an electric motor (fan) near the video cable.
Other thing to try is to change the refresh rate. In Windows XP: Control panel --> Display Properties --> Settings tab --> Advanced button --> Monitor tab --> Screen refresh rate. The default ot 60Hz for LCD monitors. Bump it up to 75Hz. That could give a clue to the problem or maybe even fix it.
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
315 people viewed this question
Henry  Thomas
Henry Thomas
