Question about Pentax *ist DS Digital Camera
Problem with the * ist DS and 2 gb chip
I just purchased a 2 gb SD chip for my * ist DS, I placed the chip in the camera and it registered 695 pictures at the highest Jpeg. Great! the problem is when I format the chip in the * Ist DS it only comes out with 340, as if it was a 1 gb chip. The strange part is if I format the chip in my Minolta point and Shoot it formats the full 2 gb. Any one else have this problem?
    Master:
  • 542 Answers
I guess You should wait for a firmware update - and do not format the card in the camera until then. I think it won't take long.
Posted on Sep 08, 2005
SOURCE:
My Pentax ist DS keeps telling me memory card error. I know there’s nothing wrong with the memory card as it’s brand new
Is the card too big? Some old cameras -- and an ist-D is very old in digital camera terms -- are limited as to what capacity chips they can use. Check your manual or Google it. Also, it's not unheard of for a chip to be defective right out of the box. Try it in another device to ensure that it's not a defect.
Mar 07, 2018 | Pentax Cameras
Unable to use SD card higher than 2 GB capacity
If you're using a card larger than 2GB then it's an SDHC card, not an SD card. The *ist DL works with SD cards, which top out at 2GB. Even though higher-capacity SDHC cards will fit into the slot, they will not work with this camera.
Dec 30, 2013 | Pentax Ist D 6.1mp Digital Slr Camera With...
Memory card error
Clean the contacts of the SD card and check the contacts of the camera. Some foreign material could prevent the cards working. You can try another SD card to see difference.
Simple thing but check also the SD card write protection is off (side of the card).
Sep 01, 2013 | Pentax *ist DS Digital Camera
What is the largest capacity SD card that I can use with a Pentax IST ds camera?
The camera uses SD memory cards. SD cards max out at 2GB. SDHC cards run from 4GB up, but they cannot be used in SD devices. SD cards can be used in SDHC devices.
The short answer is 2GB.
Jan 11, 2010 | Pentax *ist DS Digital Camera
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
I want to obtain a larger memory card (currently have a 1GB) but everyone we buy I have been unalbe to get them to format/ I have a pentax ist DS
You should be able to use 2GB SD cards. Cards larger than 2GB are actually SDHC cards and will not work with this camera.
Oct 13, 2009 | Pentax *ist DS Digital Camera
R4 will not load on nintendo ds
u have to download the kernel from the website your r4 has
Mar 10, 2009 | Nintendo DS Lite Console
Pentax IST DS & 2 GB SD cards
You need to upgrade the firmware on the camera. The latest versions will support cards bigger than 1GB; as delivered 1GB was the max.
Oct 24, 2008 | Pentax *ist DS Digital Camera
Why is my *ist DS eating my SD cards?!
I've used Sandisk Ultra II 512M cards, a PQI 1G and a Transcend 1G card (all high speed rated) in the *istDS. I've done about 1500 exposures now, many RAW, and have done several rounds of upload to my computer. No problems at all. These same cards work flawlessly in a Panasonic FZ10 as well. Either you have had a bit of bad luck, two defective SD cards in a row, or have a *istDS with a stuck or bad memory card controller. Try using the Reset command in the Set Up Menu, see if that helps. BTW, always format SD cards with the camera once before you start using them.
Sep 13, 2005 | Pentax *ist DS Digital Camera
SD card for *ist DL
Interesting... I've heard that (for the DS at least) the camera isn't capable of using more than about 60X, but of course your downloads can be faster if you use a reader. At 2gb, this might give you some benefit, but a full transfer of 1gb on a garden variety sandisk only takes a few minutes.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Pentax *ist DS Digital Camera Logo
76 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
