Question about Dryers
Kenmore 417-91702000 washer/dryer stack
My dryer is leaving burnt marks on clothing and even tearing some of it. It was making a loud rumbing type noise as well. My husband tried to take off the front to look at it last night and just about destroyed it getting it off. We found coins and lots of lint so we removed those items and put it back together. Now it sounds even worse almost like a piece of metal is in there. It still heats up fine but I can't bear to listen to it and am afraid to lose any more clothes.
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
STOP DO NOT USE IT!!!!!
This is a fire hazard, and if it is a gas dryer , worse!
Very dangerous !!!
Call service ! Do not let hubby try to use his ego, or you will be right again, and perhaps without a house or hubby too!!!!!!!!!!
Below I left you a good service, if you need them
If the appliance is 10 years or older its not worth investing money to ix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Kenmore stack dryer burns clothes
HI CAROMIA.unusual but check basics first1-dont overfill 2-no sintetics and nylons.if still burns its obviously overheating.3-check vents.hope this helps.ali
Jun 20, 2012 | Kenmore Dryers
Washer leaves oil type stain on clothes.what could be cause?
Stains on clothes from this model of washer are usually caused by the door boot or the tub bearing going out. I recommend cleaning off the surface of the door boot and if you still get stained clothes I recommend having the rear tub & basket checked. I am also sending you more troubleshooting tips in the image below.
Dec 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 417.80042990 (10 year old) dryer makes a squeak as it tumbles the clothes dry. Seems to be worse as the clothes get dryer. FYI-the felt was replaced about 4 years ago, not sure it's that. But...
this is a frigidaire made dryer with kenmores name on it. The drum bearing needs more grease. You really need to know what your doing before you take that job on yourself. Its easy for me...but I have been doing it for 20 years and thats the way I role
Nov 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
My dryer is leaving burn marks on all my clothes...is this the heating element?
NO. You have a bad safety limit switch not breaking the heater circuit when the heat gets too high.
Jul 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
Burnt lines
Your problem is a bad rear drum seal-if these become worn, torn, or missing close can get caught torn or discolored in the space between the clothes drum and rear of the dryer. Replace the rear drum seal.
Aug 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
224 people viewed this question
Top Dryers Experts
