Question about OKI B4350 Laser Printer
Oki B4350 all the printer keeps saying is check ram then it starts over and the same thing
  • Anonymous Nov 19, 2008
    all the printer keeps doing over and over is ram check...is there a solution?
I had the same problem and just now spoke with the Swedish OKI support, according to them it's the memory check that won't finish. This memory is located on the controller pwb and is probably more expensive than the machine itself! Change the controller pwb and the problem should be solved!
Cheers / Stefan
Posted on Dec 10, 2008
En la pantallade la impresora oki B4350 me marca error 134
Tengo una Oki mc361/mc561 me da error 134 como puedo solucionarlo
Aug 26, 2011 | OKI B4350 Laser Printer
Screen says change drum
Your printer is telling you it needs a new drum. Go to a search engine (Google or similar) and type:
oki b4350 drum
The results will show you where you can purchase a replacement. They look to be priced between £115 and £160. The replacement should have instructions on how to fit it.
Best of luck.
Nov 29, 2010 | OKI B4350 Laser Printer
OKI B4350 error 173
That is a temperature error with the fuser, most likely the thermistor. Really the fuser needs to be replaced. Hope this helps.
Feb 22, 2010 | OKI B4350 Laser Printer
Computer shuts off when a document is about to print.
first you should un install your driver,then install it again.
Jun 26, 2009 | OKI B4350 Laser Printer
Changing the toner cartridge in an oki b4350
Is it a OEM cartridge, which means that its made but the manufacturer of the printer. If it is a refurbished cartridge then it will probably not be "recognized" by the printer and subsequently tell you its low on ink.
Jun 23, 2009 | OKI B4350 Laser Printer
I have Oki B4350 printer. The print on both edges
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored .
Jun 03, 2009 | OKI B4350 Laser Printer
When printing all I get is a message saying invalid data (printer B4300)
I had same problem and when I installed OKI B4350 (PCL) driver it started working fine.
Before I had OKI B4350(PS) driver installed and it gave me invalid data error everytime I've pressed print.
I hope this works for you too.
Cheers,
T
May 22, 2009 | OKI B4350 Laser Printer
Oki B4540 keeps saying
You should certainly start by looking at the toner cartridge to see if there is any tape to remove. If there is no tape with a visible pull tab, check inside the printer to make sure that there are no pieces of torn paper stuck anywhere inside.
May 05, 2009 | OKI B4350 Laser Printer
Initializing... RAM CHK
Power supply is defect.
Probebly 2 ELCO's are exploded or ball.
Greatings,
Wim
May 27, 2008 | OKI B4350 Laser Printer
OKI Printer B4350
The Solution is:
You must have the Oki Monitor Software installed
When you enter in to the software you have a button that say "Maitenace", then you have a option that says " Reset Drum Counter" or somthing similar. Click on the option and the message disappear from the display.
Sorry my bad english
Nov 23, 2007 | OKI B4350 Laser Printer
OKI B4350 Laser Printer Logo
708 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
