Question about Samsung Televison & Video
Samsung lnt466f.tv wont come on.If I turn it off and on several times it comes back on and play the rest of the day.Next day I turn it on and nothing.Intrmiten problem
  • Samsung Master
  • 19,396 Answers
Try first unplugging power cord for 30 minutes or more.
Posted on Aug 28, 2008
  • Ginko
    Ginko Aug 28, 2008
    If TV does not come on at all, like there is no power then it is either a faulty power cord, or a bad contact on power supply inside tv.
    The TV does not turn off because it does detect that something had gone wrong, could have been an overvoltage, a loss of power, or a faulty component inside.
    A safety switch keeps tv off.
    By unplugging for a while you drain power out from tv and reset it. Sometimes it solves the problem.
    If the above did not help the only solution is a technician testing power board and main board inside TV to find the fault.
    If you need repair service you can call the number listed in TV owner manual.
Morning problem
Your TV is not worth fixing im afraid.
Mar 01, 2014 | Samsung Televison & Video
Samsung46 inch lnt466f
Being that it is less then a year old it is still under factory warranty I would recommend having it serviced that way.
Thanks,
lee
Aug 28, 2008 | Televison & Video
Samsung Plasma tv pn43d450 tv wont turn on
If caps there not puffed or leaking voltages in and out of the power board must be checked next (right at turn on of the set) to see which come up and or instantly go off....this is the place to begin.
Mar 27, 2012 | Samsung 43 PN43D450A2D Plasma TV
Tv wont turn on
Green light of death, capacitors have to be replaced but it probably wont fix it anyways. Once this happens the TV is completely useless.
Jul 21, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Tv wont turn on
Hi!
Try to check the back cover. If it is wet may be their was a short circuit. Have i t check to a qualified technician so that no further damaged maybe incurred by the unit. Power supply is affected if it was plug in for a long period of time with out unplugging it from the outlet. If it was turn on again it must be unplugged and rest for about half a day coz the power supply still received the current from the source.
Please specify if you have experience checking it with the technician?
Jonags
Dec 31, 2009 | Televison & Video
Red light flashes but TV wont turn on
If you dont have the led light on when plugged go ahead and replaced the powerboard, but if your led light is on when plugged then you will need to replace the mainboard.
Hope this info help you.
Jul 01, 2009 | Samsung LN32A330 32 in. LCD TV
Picture goes off
A temporary solution is to unplug the TV for a few minutes, remove static from the glass with your hand. It is important to unplug rather than turn off. If you have a degauss button you can also press that before unplugging. Wait several minutes or an hour. Then plug it back in. If you have Picture in Picture it may be an issue with that and to permanently solve may need a repair person. The unplugging may get you by for a few days at a time. That's at least better than an hour.
Mar 13, 2009 | Fisher PC-32S90 TV
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Wont power on
buddy of mine had the same thing, i looked in side and it had a fuse out. the tricky part was finding it. his had 6, two you could see the rest- well lets say you have to look and not play super man. works but i have to now find a way to re- fous it. any one how?
Nov 25, 2007 | Samsung HCM5525W 55" Rear Projection...
Searching for signal, component connection
  • the problem is in the system control section of your tv
  • it might be due to loose connection in that section
  • some components must have failed.
  • loose contact in any pin of system control ic.
  • good luck.
Oct 22, 2007 | Samsung DynaFlat TX-P3076WH 30" TV
Televison & Video Logo
180 people viewed this question
Henry  Thomas
Henry Thomas
