Question about Royal VF1012mx Shredder
A piece of junk mail from a religious organization had a "medalion" in the envelope. I put the whole thing in the shredder- royal VF1012mx. Now it is jammed makes a terrible noise.
    Genius:
  • 1,218 Answers
Unplug the machine.
Remove the waste bin.
Remove 4 screws inside underneath to take cutting head off the basket/cabinet.
Turn the cutting head over and remove 6 screws that hold the top cover onto the bottom. Turn the unit back over and remove the top cover...remove the medallion if jammed...check the gear train to see if it has broken any teeth in the drive gears.
If you need parts contact Royal at 1-800-524-0799.
Posted on Jul 20, 2011
SOURCE:
MY ROYAL CROSS CUT SHREDDER VF1012MX WILL NOT ALLOW ME TO FED MORE INTO SHRED. THE MOTOR RUNS BUT THE BLADES DO NOT TURN. THIS HAPPENED AFTER IT JAMMED AND I REMOVED ALL PAPER.
Most likely broken plastic gear inside...open it up to see which one then contact Royal at 1-800-524-0799 for parts assistance.
Jan 16, 2011 | Royal VF1012mx Shredder
Overload light keeps coming on but there is only 1 piece of paper at a time
Have you ever "oiled" the machine...get shredder oil and put some into the cutting blades and run the machine in reverse..then put some of the oil on some paper and run the paper thro" the machine.
Nov 18, 2010 | Royal VF1012mx Shredder
Need plastic gear for vf1012mx
Give Royal parts a call at 1-800-524-0799 they will be able to help.
May 14, 2010 | Royal VF1012mx Shredder
Lost Manual for Shredder
Not on-line that I know of but give them a call at 1-800-524-0799 maybe they can fax or e-mail something to you.
Jan 01, 2010 | Royal VF1012mx Shredder
WHERE CAN i BUY A MOTOR FOR A ROYAL VF1012mx
For Royal parts give them a call at 1-800-524-0799;... they should be able to help.
Dec 14, 2009 | Royal VF1012mx Shredder
There is paper stuck in the shredder how do I get it out. I have tried the reverse and forward several times.
IF YOU GET A PIECE OF THICK PAPER OR AN ENVELOPE AND FEDD THAT THROUGH IT SHOULD CLEAR IT FOR YOU YOU COULD OPEN THE DOOR AND FEED THE PAPER UP FROM THE BOTTOM BY CHEATING THE DOOOR SWITCH BY PUTTING A PIECE OF PAPER IN THE SLOT FOR THE ACTUATOR THAT WILL LET THE MOTOR RUN FOR YOU...hOPE THIS HELPS a
Jul 30, 2009 | Royal VF1012mx Shredder
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
Have a royal vf1012mx shredder that overloads everytime i try to shred.
Put in less thicknesses. Also, put them in in the center. If they are near the edge and they are at an angle, they will flip over themselves and double the thickness.
It is designed for 12 sheets of paper. They probably figure on 18 pound paper, not 20. Adjust what you put in to allow for this.
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
VF1012MX Shredder
Call Royal at 1-800-524-0799 and describe part they can normally help.
Dec 27, 2008 | Royal VF1012mx Shredder
Royal VF1012mx Shredder Logo
371 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
