Question about PSC Office Equipment & Supplies
Barcodes for the psc 959 scanner
When i create barcodes it will work for 2 digits, however it will not scan for a single digit. Do I need to add something else to the barcode in order for it to scan?
3 Suggested Answers
SOURCE: Scan a single digit character
i have problem with when i goint to scan after 5 or 10 minutes after it disable, and then we go to connect and disconnect to work
Posted on Jan 14, 2010
kmcnew1980
  • 60 Answers
Some scanners are programmed by default to not scan some barcodes below a certain length. Before a solution can be given, we would need to figure out what symbology the barcode is. Please call Barcode Trading Post at 888-317-3440 for assistance.
Tech Support Barcoding Technical Support
Posted on May 20, 2016
Why i cannot scan 1 digit number
Did you make the barcodes using Code 39 or 3 of 9? If so, the scanner defaults to reading between 2 and 55 character Code 39 barcodes. Go to the Motorola Solutions support portal and search for Article ADC-00404 portal motorolasolutions com. Print the article and scan the Code 39 Any Length barcode. Once this is done the scanner will read all Code 39 barcodes.
Aug 12, 2014 | Symbol LS 4278 Barcode Scanner
Symbol 4000i scanner will not scan barcodes that are single digit
Hello Jane Diaz,
the scanner has several barcode types enabled by default. Other type or lengths must be activated with an programming barcode from the Programm Reference Guide for LS4000.
Please check which kind of barcode are you using. Download the Program Reference Guide from support.symbol.com Scan the barcodes from the chapter Symbologies
Oct 13, 2010 | Symbol LS 4000i Handheld
Nov 25, 2009 | Symbol LS 2208 Barcode Scanner
I have not instruction for default settig where are barcode for default setting
Check metroselect single line configuration guide page no. 2
1) Scan Enter/Exit configuration mode it gives 3 beeps
2)Scan recall defaults it gives single beep
3)Scan Enter /exit configuration mode it gives 3 beeps
Now scanner is set to default setting
Sep 16, 2009 | Microsoft Metrologic MS9520 Voyager...
PCS Magellan Scale Scanner How can Programm the scale
i scan the bar codes in the manual north america than 4 digit price check and that was it.
Aug 29, 2009 | PSC Magellan SL
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
It doesn't read!!!
is this a spam or something?
Jun 24, 2008 | PSC (22000-0011050-60) Hands Free
Psc quickscan 6000plus
That scanner has been constrained to accept a digit length of 12 or less .. probably IPC codes which are 12 digits in length.
Do you know the symbology of the barcode you are scanning? (i.e. UPC, EAN, I2of5, C3of9 etc).
Dec 27, 2007 | PSC QS6000 Plus Handheld
Programming GP5385 to scan 20 digits
Dear Huygen, Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it by scanning it to factory configuration,or scan a label that would enable all symbologies.
Jan 19, 2007 | PSC Quickscan GP5385 Handheld
751 people viewed this question
Top PSC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a PSC Office Equipment and Supply Expert? Answer questions, earn points and help others
