Question about HP iPAQ HX4700 Pocket PC
Soft Reset erases everything
I know this may sound daft but I'm on my 6th PDA now and have got into a habit of turning the unit on by performing a soft reset. Not everytime of course but I may remember that I have had a lot of apps running as i pick the unit up so I just press the reset button to turn it on in a nice clean state. However, on my 4700 i press the reset with the power off and i can't turn it back on again, the only way i can get the unit back on is to remove the battery, then the unit boots up in default. However removing the battery normally is fine and press the reset when the power is on is fine. Can anyone confirm if there unit does the same ?
    Master:
  • 450 Answers
Hi, i remember reading somwhere that if you hold the soft reset button too long you will deactivate the battery. You can reactivate it by inserting the PDA into the cradle. Hope this helps.
Posted on Sep 08, 2005
When I turn my Garmin Nuvi 680 on, and the first screen appears about not driving while operating the Garmin, I have to hit "agree" button several times before it goes to main menu, and from that...
Try performing a soft reset.
Disconnect the unit from any external power supply.
Depress the reset button behind the flip up antenna.
Reconnect the unit to the power supply and let it should work normally.
If the soft reset does not work, try performing a hard reset.
Caution: Performing a hard reset will erase all user information including favorites and bookmarks and restore the unit back to factory settings. Be sure to save any information before performing the hard reset.
With the unit off, press and hold the lower right hand corner of the screen while turning the power on until a pop-up appears. Press "Yes" to restore the unit back to factory settings.
Sep 21, 2011 | Garmin Nuvi 680 GPS Receiver
My first problem arose yesterday when, while syncing my E2 with my Desktop MAC OSX 10.4.11, the sync operation failed and the hand held Tungsten E2 could not be opened turned of and none of the prorams on...
Hi
you may perform soft reset, if issue persist perform full reset. please do not forget to backup your important data. let me know when you need further assistance so I will post the solution depend on the result.
Mar 14, 2008 | Computers & Internet
Tip
Visor Deluxe does not start
Hi.
The procedure below shows how to reset the PDA to factory settings after backing up all your personal data.
After backing up your data with HotSync, perform a hard reset, this will erase all applications and returns your device to its factory default settings.
To perform a hard reset:
1. Hold down the power button on the front panel of the PDA.
2. While holding down the power button, use a paper clip to press the reset button.
3. Release the power button.
4. You will get a message warning that you are about to erase all the data stored on the PDA, do the following:
Press the top scroll button on the front panel
to complete the hard reset and display the startup screen.
If you press any other button you will do a soft reset, that will not fix the problem. In that case restart the procedure.
5. After doing hard reset the unit will return to the initial factory state. All third party installed applications will be deleted, and setting will be reported to factor default.
Connect to HotSync and do a backup of the PDA, then do hard reset on Palm.
If the PDA is not detected by Hotsync, then there is an additional problem.
To troubleshoot problems given by third party application you do a backup, then rename the backup folder containing third party application data to Backup.old, and do hard reset.
After that you start restoring applications from backup.old one at the time, when one application jams the Palm, that is the responsible for the error message.
Procedure is described here.
Regards.
G.
on Apr 09, 2010 | Handspring Visor Deluxe Handheld
Garmin 660 touchscreen inoperative
Sep 18, 2011 | Garmin Nuvi 660 GPS Receiver
It tells me that I don't have enough memory and should delete data files App 8004 and App 8002. I don't know what I can remove without damaging the performance. What can I move to the extra card I have
Hi.
To start you can delete safely any music or video file.
If that is not enough to fix the problem, then the best thing to do is resetting the PDA to factory settings after backing up all your personal data.
Regards.
Mar 02, 2010 | Handspring Visor Deluxe Handheld
PDA will not perform any of my commands..its frozen
Hello, Tallman.
I'd suggest to perform a soft reset then a hard reset, if the soft reset doesn't work.
Then if necessary, as this may or may not be a simple solution, depending on your particular brand and model:
Remove the back of the PDA. Remove and reinsert the battery.
Hope this helps.
Jan 09, 2010 | Palm Computers & Internet
After a soft reset, my Palm TX becomes stuck on the "Palm Powered" screen. I have tried all of the resets, including the hard reset. The PDA does not respond to any of the resets. I can not turn the PDA...
You need to perform full reset which will erase all personal data and set everything to factory default. You need to press reset and power button to perform full reset.It will give you confirmation once you choose yes it will perform hard reset If issue persist you may disconnect and reconnect to internal battery
Aug 02, 2009 | Palm TX Handheld
Acer N30 PDA charging problem
My PDA n30 is not a year old yet - when I put it to sync and charge everything looks fine but when I unplug it does not stay charged - it blacks out straightaway.
Please help
Jun 09, 2009 | Acer n30 Pocket PC
Dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
Hard reset
Occasionally, you may need to reset your device. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings — the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile software and other pre-installed programs will remain.
To perform a soft reset
Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
  1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
  2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
  3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Oct 29, 2008 | HTC P3300 Smartphone
HP iPAQ HX4700 Pocket PC Logo
53 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
