Question about Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive
Secure HD Login Problem
I have one of your external hard drives on a Macintosh Powerbook I upgraded the powerbook and now it will not recognize the hard drive the Cd part shows up but when I click on the secure hard drive icon it does not recognize it. I tried to uninstall it but I get a message " The OnSpec Secure Login requires Mac version below 10.4 and above 10.2". My new computer is 10.5.2. How can I access this hard drive
  • 600 Answers
In applications there is one called utilities in this is one called disc utilities see if the drive shows up ? if it does try repairing permissions and verifying the disc.
Posted on Sep 04, 2009
Want to free up space on my internal hard drive (Apple PowerBook G4) without
Mac do not waste space, I recommend you to use an external hard drive. Try to find one with twice capacity that your computer's hard drive.I mean, if your computer hard drive is 500Gb, then find an external drive with 1Tb
Oct 01, 2012 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Usb not recognized on macintosh powerbook g3
The Powerbook G3 will be using the original USB architecture and I suspect that your flash drives are using USB 2 and are not backwards compatible, so sorry I don't really think it is possible.
Dec 16, 2011 | Apple PowerBook G3 Mac Notebook
My system doesn;t boot up and I don't have the CD to boot up my system. When I brought the powerbook G3 it didn't with the CD. Please where can I get it from? I am in Ghana now. Thanks Ishmael
If you have another Macintosh that is working correctly, you can copy the contents of that hard-drive, including the Operating System onto an external hard drive.
To do this, install Carbon Copy Cloner on the working machine and plug in an external hard-drive. Then run Carbon copy cloner and make the source the computer's hard drive most likely named "Macintosh HD". Then choose to have your external hard drive be the drive where all of the data is copied. Then run the program and let it copy all of the files.
Once this is done, remove the external drive from the computer and plug it into your G3. Turn on your G3 while holding the Option (alt) key and then double click on the hard-drive image that is named whatever your external hard-drive is named.
Once your system boots up from the external hard drive, run Carbon Copy Cloner again and repeat the process again except have the source be your external drive and have the internal drive in your G3 be the disk that has all the data copied to it. Once this is done, turn off your computer, remove the external drive, and then boot up your computer again.
You will have an exact clone of the computer that you copied the data from and will just simply need to adjust the account settings as such as you see fit.
The external drive process can be skipped if you have a firewire cable. Simply connect the firewire cable to both computers and when you turn on your G3, hold the "T" key. This will turn your G3 into an external hard drive and you just have to carbon copy the files straight to your computer's internal hard drive.
If you do not have access to another computer mac computer, then you will need to go to the Apple Store and see if the Genius Bar can install the default operating system that your computer came with.
If for some odd reason you have the contents of an Mac OS install disc copied onto a flash drive or external hard drive, you can boot from that and use it in place of a disc.
Apr 15, 2011 | Apple PowerBook G3 Mac Notebook
Light blinks on my portable WD elements 500 but the computer dosent recognize it. Im using a Powerbook g4 power pc. I have info in it i need to reach & other computers recognize the HD but not my...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 14, 2011 | Western Digital 500GB ELEMENTS 500 GB USB...
I have a powerbook G4 and just purchased a Seagate 500 GB external hard drive and i can not drag and drop do i need to format something or what ?
You should use the Disc Utility in Macintosh >Hard Drive> Applications>Utilities>Disc Utility to format the new externql to Mac OS Extended Journalrd or non-Journaled is fine.
For video applications I prefer non-Journaled.
Select the drive on the left side of the window to highlight it.
Select the Erase tab. (Top of window)
Select VolumeFormat: and Name:
In Secutity options select Zero Out Data, hit Erase (middle of window) and wait for formatting to complete.
Could be an hour or two depending on disc size.
Apr 03, 2011 | Apple PowerBook G4 Mac Notebook
How do i back up a power book g4? What application do I need to do the back up?
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple Macintosh PowerBook G3 Start-up problem
Your mac doesn't recognize the system folder. Try to find the original boot disks that came with the machine, and see if you can mount the hard disk while booting from the CDs. If you can, I'd backup the data as soon as possible and reinstall the operating system, including a full hard drive reformat. If you can't see the hard drive from the boot cd, another option is to hold down the T key during startup to boot the mac into "target disk mode" - this will allow you to hook up the g3 to another computer as an external hard disk in order to back up the data.
Oct 21, 2009 | Apple PowerBook G3 Mac Notebook
WD Passport Essential 160gb with PowerBook G4
The problem is that your powerbook G4 does not provide enough power to your 160gb passport HD. This does not happens to the new Macs with intel inside.
There are several ways to fix it:
1) Go to West Digital Website and buy a "Power Buster Cable USB" (that connect your 2 USB ports to your passport HD in order to provide more power). I think that it costs 10$. This is the link:
2) The other solution is easier. If you have an external USB hard drive with two USB ports, or a DVD/CD burner with two usb ports, you can pug your passport in one of the ports while the other HD or DVD/CD burner is connected to you PowerBook. You will be able to see and use your q60gb Passport HD.
Oct 21, 2008 | Western Digital Passport WDXML800UE...
My powerbook g4 won't recognize my external hd or my web cam but it recognizes my ipod.
I am not really sure but i think the Camara and the External Hard Drive have to be compatible with Apple I think so you can use it. An IPOD is made by Apple so thats why your G4 recognizes it. I would just buy like a USB Drive. And also try to download the Drivers also and you can do that by google-ing it that sort of think. Anyways just use a windows based computer Bro its much more efficient. Let me know how it goes alright.
Oct 02, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Worked fine on my macbook but not by my powerbook g4 or any other computer
I would suspect a corrupted catalog file, these are the map that a comupter uses to find its way around the drive, they are also the first casualty when a crash corrupts something. Disc warrior will write a new catalog and fix everything. PCs do not see discs formatted for macs.
Aug 21, 2008 | Hitachi 500GB External USB 2.0 Hard Drive
Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive Logo
852 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
