Question about Pentax AF-360 FGZ TTL Flash
Flash won't fire on p-ttl mode
I tried out the 360 flash on my DS and ran into a hitch. With camera on autopict or program the flash won't fire on p-ttl mode. It also won't show the allowable distance range on the flash scale. The viewfinder gives the exposure for no flash. I have the DS set to factory presets (except no screen graphics). The flash will fire on ttl but not give distance readout. I was doing this with 16-45 lens. Is there something else that needs to be set on camera menu or on flash? I went thru the ib. Also tried on another DS with 18-55. Same deal.
    Master:
  • 542 Answers
The AF360 can be in TTL mode until it is mounted on a P-TTL compatible camera and turned on, then it senses the camera and goes to P-TTL. However, sometimes in the past when I got TTL and it should have been PTTL it meant that either the batteries were not connected properly (I know, sounds strange, but check the battery compartment cover to make sure it is seated properly and make sure that the batteries are all in proper position), or that the AF360's contact pins were not all making proper contact with the shoe or extension. Beyond that it could be a faulty flash. You have swapped lenses and cameras with the same result, how about swapping flash? Unfortunately that may be your problem.
Posted on Sep 08, 2005
Nikon Speedlight SB-24 TTL Flash
First off be aware using all caps is viewed as yelling and being rude. Also, be observant we do not see all caps used in newspapers, magazines, or the like, thus we do not need them on the web.
To answer your question: You can use almost any flash on your D60. While some will work with all the features of your camera some will work with some your camera will fire the flash. Some flash will only work in manual mode. Manual mode is the mode I use 99% of the time. For me TTL is to inconsistent.
Oct 09, 2013 | Nikon Speedlight SB-600 TTL Flash
D90 Built-in flash won't fire
Go in menu go to bracketing /flash then set for TTL
you should work to test leave lens cap on push button on left side with lightning bolt on it.
Oct 18, 2012 | Nikon DSLR D90 Digital Camera
I've mislaid my manual for my Metz 54. I haven't used it for a while and can't remember how I set the thing to shoot in ttl with my Fuji S6 Pro. When I'm in ttl mode on the flash the camera doesn't fire....
Not sure what S6 pro is, but if the flash doesn't fire in TTL then the flash is not support the type of TTL in the camera. I had the same problem with Nikon flashes on Nikon bodies. Perhaps you need a newer SCA adapter? Please go on http://www.metz.de/en/photo-electronics/sca-adapter/archive.html to check which adapter you need
Jul 02, 2010 | Metz 54 MZ-4 for Nikon TTL Flash
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
Sb800 is on mode lcd panel showing all ok buti pres flshfire flash not fire
What's "flishfire"?
Try this:
Remove flash from camera.
Turn on flash
Wait until ready.
Short out center pin to outside contact, this should fire the flash.
atdlee@netzero.com
Jan 14, 2010 | Nikon Speedlight SB-800 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Sb 600 under exposure.
    You probably haven't changed the camera and/or flash back to TTL mode from wireless mode.  Make sure they are both set to TTL, not commander mode and you should be fine.  Note that the LCD on the flash will indicate which mode it is with a little graphic.  On the D70 you had to switch between TTL and Commander mode to set it up to work using the built in flash as the commander, so you just have to switch back.
    Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
    Flash on ist DL
    Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
    Sep 08, 2005 | Pentax *ist DL Digital Camera
    Pentax AF-360 FGZ TTL Flash Logo
    255 people viewed this question
    Top Pentax Cameras Experts
    Geoff Hone
    Jerry Greenberg
    Jerry Greenberg
    Are you a Pentax Camera Expert? Answer questions, earn points and help others
