Question about Compaq tc4400 Tablet PC
Problem with Restarts
My Tc4400 when i turn it on after loading the screen that have windows xp and the loading bar it restarts itself. And when i try to get it to safe mode it loads and still restarts itself. Any mode i try even continue to last known good configuration it restarts. I cant even get onto the first window screen to type in my password.
What can i do to stop it from restarting when it loads
  • tho_nguyen30 Aug 30, 2008
    The laptop itself dont have a CD Drive so do i have to buy one for it and put in the CD for it?
    Or theres something wrong with the Hard Drive?
I have the same prob kinda my compaq presario 5301rsh will load up fine but when i use any thing on it it shuts off then restarts..i tried power supply's,ram chips, new dvd drives,processer,unchecking the check mark in the advanced area to where it restarts and should give blue screen but it dont,i formated and reinstalled xp gave a bios update and even took all hardware and proccesser out put all in another cpu that works...no restarts,,but when i put all back in to my board the retarting begins...any ideas????
Posted on Sep 09, 2008
    Problem Solver:
  • 6 Answers
This problem may due to virus , so better you reinstall your system
Posted on Aug 28, 2008
Wwhy is my tablet froze to EFI MODE
I figured it out. If you did by accident loaded EFI shell and your pc then restarts and crashes sortly after selecting safe mode settings (as if it wishes to load) but a faint blue screen appears then it restarts and same problem.
I am using an XP Home edition package to a H71M-DGS motherboard but this should not matter so longs as you haven't formatted your HD.
Solution: If to reset CMOs manually or in BIOS load default settings does not solve your problem, and even trying a different SATA port :P. Then look at your SATA configurations. I found that the default setting was ADCH then set it to IDE and that should allow boot to your oldish HDD. Hope this solutions helps some may not be the solution for all.
Sep 15, 2017 | Tablets & eReaders
Compaq tc4400 suddenly turned into non tablet pc (pen & touch gone)
http://www8.hp.com/us/en/support-search.html?tab=1#/qryterm=compaq%20tc4400&searchtype=s-002
this is where your find the moel drivers for tablet , there are two available , so please read before installing.
Nov 27, 2013 | Compaq tc4400 Tablet PC
HP TC4400 hard drive ugrade problem
go to hp site and check is the model support 320gb hdd or not if not trun yr hdd in limited capisity
Feb 26, 2010 | Compaq tc4400 Tablet PC
Keeps freezing after loading windows xp, won't allow me to use any apps or open anything
if you cant afford to get it repaired, then check the processor, hdd, ram slots to ensure that they are all in their fixed possitions,
the problem may be that a module of ram has come loose or your processor has, if they haven't then get yourself a digital multimeter and learn about computer electronics,, although buying a new computer maybe the quickest option.....
May 31, 2009 | Compaq tc4400 Tablet PC
Startup problem
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
Dec 20, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Hi i need driver o software pen ( compaq tc 4400 XP )
I belive you will find what you are looking for on this page please follow this link to download your touchpad/PEN driver >
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1849071&prodTypeId=321957&prodSeriesId=1847962&swLang=8&taskId=135&swEnvOID=1059#11318
just copy that link and paste it into your address bar at the top of your internet browser then hit search or press enter.
hope this helped you but if it does not help please do not hesitate to re post your issue and we will keep trying to solve it for you.
Thanks Reguards: PC Pro
Dec 15, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Non System disk
a) remove any external devices and reboot.
or
b) boot from Windows XP setup-cd into rescue-terminal, execute: fdisk /mbr
or
c) do a hdd self-test in bios (restart, press F10, tools --> hdd self-test option --> notebookharddrive) to check the integrity of your harddrive
Sep 21, 2008 | Compaq tc4400 Tablet PC
I'm having problems upgrading from Windows ME to Windows XP Professional..
Clean the CD and see if that works. Are there any scratches on it?
Jul 18, 2008 | Toshiba (K000680310) for Satellite...
Restarts before windows loads up.
hey hey chill...simple my friend just have your windows service pack with you inhand.Turn your Laptop on immidiately when your CD-ROM/DVD-ROM starts flashing its light, open it then insert your service pack disc (its the CD/DVD you receive when purchacing the laptop) then let it restart again...then again when it starts press F8 repeatedly until you enter a some menu then re-install the Windows Xp again from the disc and walla your Pc will be fresh again...
Feb 24, 2008 | Fujitsu Siemens Lifebook T4010 Tablet PC
Problem: Cannot Load Windows/Windows Setup Does Not Detect Hardrive
My Hp Compaq tc4400 Does not load Windows and when i try to install a new one and error Message apears saying that it cannot detect any hardrive, but when i press F9 for boot selection Notebook Hardrive is dected and availble, i tried removing the hardrive and re-insert it also it dint work could somebody help plssss
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Compaq tc4400 Tablet PC Logo
238 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
