Question about HP iPAQ hw6515 Pocket PC
Pictures When the 6515 is charging, it shows pictures in the internal memory as a slide show. How can I do the same with the pictures in the SD card ?
    Master:
  • 450 Answers
I purchased Dockware Pro when I had my hx4700. I don't recall if the basic verison does that (sorry waiting for the US launch of the HW6515). If it doesn't offer an external memory section then you might need to upgrade.
Posted on Sep 08, 2005
Micro sd adapter i keeps in camera it is shows card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 18, 2013 | Canon Cameras
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 06, 2012 | Canon PowerShot S2 IS Digital Camera
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
My camera won't show any pictures from my SD card
You have to change the 'storage' to 'memory card' or 'external card' from 'internal memory' or 'camera' using the camera menu.
Dec 10, 2011 | VistaQuest VQ-5115 Digital Camera
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
I just got a kodak slice 14 megapixle.. with out a memory card it only takes about 20 pictures.. where is or how do I find out the internal memory,... It looks like even if I use a 4 gig micro card. the...
Depends on the size of the images - if you are using best quality and large size, the number of images will decrease accordingly. Look in the manual for the correlation. BTW, the internal memory and the SD card are not the same thing.
Jul 09, 2017 | Kodak SLICE Touchscreen 14MP Digital...
How do i unlock my memory card its not allowing me to take photos.
I am assuming that your camera uses and SD card to store the pictures.
If you remove the memory card from the camera, you should see a little slider on the side of the card that says "lock," it is easy to accidentally lock SD cards.
I have attached a picture to show you what a locked SD card looks like.\:codyrt.jpg
Here is another image showing the card in the unlocked position: codyrt_0.jpg
I’m happy to assist further over the phone at https://www.6ya.com/expert/cody_a1e78820c0d52932
Mar 01, 2011 | Cameras
Just put a new memory card in the camera but the screen keeps showing internal memory is full
How to switch the camera over to saving pictures directly onto the SD card.
    1. Menu
    2. Cam settings
    3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Does the digital photo frame have it's own internal storage, or do I need to purchase an SD card?
    Most digital photo frames have a small internal memory limiting you to the amount of pictures that it can show. If you want to have a slide show of a couple of hundred pictures or more then an SD card would be a good idea.
    Regards.
    Jul 27, 2009 | Coby DP-768 7-Inch Widescreen Digital...
    HP iPAQ hw6515 Pocket PC Logo
    52 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
