Question about Daewoo DWC063R Air Conditioner
High pitched whistle
After using my cordless phone close to the unit, a high pitched whistle emits from the air conditioner, even when turned off and unplugged. Help!
    Genius:
  • 2,920 Answers
Can u please rate my help? thanks you
Posted on Aug 28, 2008
Fan making high pitched whistle
check for debris in the air intake. I've had leaves in mine make a similar noise
Nov 14, 2016 | Cars & Trucks
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Dec 25, 2015 | Goes Motorcycles
How do I get rid of high pitched whistle in cabin air system?
blower motor might be going out. worn out bearings.
Jun 28, 2014 | 1998 Toyota Camry
High pitch whistle after closing door
It is possible that the door gasket is defective
Jul 01, 2013 | Frigidaire FFU17M7HW 17 cu. ft. Manual...
AIR CONDITIONER WHISTLING SOUND 325I BMW
make sure the belt is not loose, if the belt is OK, then your A/C pump is at fault
Mar 11, 2013 | Cars & Trucks
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
My 2003 dodge caravan has a high pitch whistle coming from the back end. what could it be
If you have a rear air conditioner, the whistle is likely coming from there, and it will require professional troubleshooting and repair.
Bill B
Sep 04, 2010 | 2003 Dodge Caravan
My water heater emits a loud high pitched whistle when it is venting. Any ideas how to correct this?
I have an AquaStar tankless and it has started making that high pitched sound when in use. I wonder if that means I have clean the heat exchanger. I called Bosch but they won't help since it is installed in a bathroom--in violation.
Jun 21, 2010 | Bosch & Tankless LP Hot Water Heater
High-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Dec 04, 2009 | Maytag MGC6430 Gas Cooktop
Freezer unit makes whistling sound
This indicated obstruction of air flow. Is there a change in cooling temperatures also? Thanks, Sea Breeze
Mar 19, 2009 | GE GSS20IEP Side by Side Refrigerator
Daewoo DWC063R Air Conditioner Logo
352 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
