Mitsubishi ws55809 TV
I had trouble with my red adjustment,i replaced both convergence chips.
My colors aline in a good cross.
But my picture on the screen is still bad.Is ther more adjustments??
Rich
  • 13,433 Answers
Recommend you ask slinteriors http://www.fixya.com/users/slinteriors
Posted on Aug 31, 2008
The picture on my tv seems to look like what my kids say 3D what could be the problem?
The problem of your tv is the convergence. Use the original remote then go to setting menu then you will see the convergence section. Try to adjust the color, you should move them left,right and up,down. If this color does't move far enough the convergence chip is defective and must be replace. This convergence chip is located inside the tv t has a large aluminum plate cold the hit sink and the chip has a marking of STK---followed by numbers if you are handy in electronic trouble shooting I can guide you but be sure to unplug the unit first or you can contact a technician to do it for and save you from stress. Good day and best regards.
Jul 28, 2011 | Mitsubishi WS-55907 55" Rear Projection...
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
I have replaced the convergence chips. the red is smaller than the rest of the grid and out of range of adjustment solder connections good was doing same thing before i replaced the chips the resistors...
Both STK convergence chips are replaced.Resistors are look good and good solders connections dosen't mean anythings.Resistors must test it with a Ohm meter and replaced those resistors are not in torleraces of it colors bands.That why ur tv convergence picture problems are not solved.
Nov 17, 2010 | Mitsubishi WT-42313 42" Rear Projection...
I can not get the red and blue crosses to converge with the green. I am not able to adjust from my remote. yet my remote does everything else. what do i do?
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can hire a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a step by step picture instruction guide, original OEM parts, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Mar 12, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Where are the covergence controls in ws55809 tv located
All convergence adjustments on this set are done with the original remote control--you will find the CONVERGENCE in the customer menu---if set will not adjust there you have a circuit problem.
I have fixed hundreds of these sets--if it will not adjust let me know and I can tell you what is needed to fix it.
SD TECH
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Cannot reset vertical convergance
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2009 | Mitsubishi WT-42311 42" Rear Projection...
I have green outlines in the pictures
go into your menu there should be something called convergence in the menu a red and a blue convergence. when you select one you will get a cross in the center of your screen use the selection keys to move this so the two crosses are on top of each other. once you align both the red and blue ( the green is the base) then go to the multi point convergence if all crosses are lined up you are good if not then you will need to replace the convergence I.C. for that color or both. let me know how this turns out.
Mar 04, 2009 | Philips 43P8341 43" Rear Projection...
Red "aura" in the middle of my 55" Phillips Magnavox
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
