Lands Phones Logo
Anonymous Posted on Jul 19, 2011
My phone # is 512-650-9926. I can't get to my voice box. Phone askes for a pass code, and I don't have or can't recall mine. Please help! Thanks! Drew Boe Harbour
Anonymous
Level 3:
  • Master 1,188 Answers
  • Posted on Jul 19, 2011
Anonymous
Master
Level 3:
Answers
1188
Questions
0
Helped
350788
Points
3656
I would be able to help if you included the carrier that you use for your phone, but I will try.
You should probably just dial 611 from your phone and ask for the voicemail to be reset. That is your best bet. Also, you could log in to your carrier's website and reset your voicemail from there.
If you need further help, send back a message with your carrier and model phone.
Thanks!
EJ
  • Anonymous Jul 20, 2011
    What cell phone carrier do you use? I can take a look for you...
    Hey Drew,
    Again, if you would like the best bet, which is to call your phone's provider. Once you contact customer service, they will reset your voicemail password for you. Just dial 611 to speak with support.
    Plus, if you would like, you can login to your account at the carrier's website and you can most likely be able to reset voicemail password after you have gotten into the site.
    Good luck!!
    EJ Kudelka
2answers
Mitel 5330e IP phone. Saying voice mailbox is full on an extension when someone rings the number but when pressing the voicemail button it says I have no messages
Try to dial voice-mail, press star and manually enter the extension and pass code. You could have another mail box notifying that phone
Bell complaints
please go to setting and select defolult setting and slove the prolbme
Trying to pair my bluetooth with my phone and it' asking for a pass code i don't have my manual so I don't know what the code is
when u connect ur phone bluetooth to any other device it need a pass code! you have to give that from ur phone manually and the other device should have to put the same code so now u use the headset option to connect to the bluetooth not the normal bluetooth conectivity !
Sep 16, 2011 • Cell Phones
2helpful
Uniden Dect1560 - For incoming calls it only rings 3 times. Is there a way to make it ring 6 times before it goes to voice mail?
Your model is a phone only, without an answering machine built in. This means that voicemail is provided by your phone service on your line, and that's where you need to adjust the rings before it picks up. The phone itself has nothing to do with it.
You may have to call your service provider for setup instructions because not all systems are the same, but here's how it usually works. Pick up your phone and call your own number to reach your voicemail. When your message starts, press the * button and the system will ask for your pass code (just like when you call to get your messages). Follow the voice prompts to reach the main menu, then mailbox settings, where you'll be able to change the ring count.
If these steps don't work for you, ask your service provider what you need to do.
2helpful
2answers
How to formate the mobile memory of Nokia 3110c
Step 1 - This will only reset your Settings.
For soft reset type *#7780# and if it ask pass code enter the pass code as 12345
Step 2 - This will FORMAT your Memory including user files and virus contents BUT it can do by Service software or Flash Box. Please go to nearest service center for step 2.
6helpful
EM227 ASKS FOR PASS CODE ..I DONT HAVE WHY?
The pass code should be 0000 but if you get it synced. It will not stay connected. Its not your htc phone. I went to HTC's website to get the bluetooth update, installed it, and im still having the same problems. Its the piece of s#*% em227 bluetooth that is the problem. Your best solution is to go and buy a new bluetooth cause yours, just like mines, wont work. Have A Nice Day
2helpful
Voice mail on my cell phone.
I am not sure what kind of help you are needing... But If you are trying to call your voice mail number it is the same as your phone number.... Most of the time the default pass code is 9999... if this works for you please let me know..
Samsung DCS Basic 12B phone voicemail
I assume you forgot the passcode to a voicemail box , not the pass code to the voice mail system. The easiest way to fix your problem is to enter voice mail programming(from a telephone) and delete the box and then create the same box again. That way the mailbox when created will come up with the system default pass code
Top Emerson Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
