Question about Ricoh FAX3900L Plain Paper Laser
Richo 3310 fax
I need the reset code for this richo fax, How do I get into the service mode?
    Problem Solver:
  • 13 Answers
What is the model? There are not all the same for the service mode. And what is the reset code for?
Posted on Aug 28, 2008
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
How to make reset for sc 542 for richo aficio 410 printer
That code requires going into the SP (Service Protocol) mode. If you have the service manual, it will tell you which buttons to press to enter it and to exit service mode. Once you enter service mode, power down the printer. If that doesn't reset, you have to go back into service mode, go the the SC/Fuser reset SP and once executed, power down then restart. Hint: you have to go to "SERVICE" then 1 will display. Press the right arrow key until you reach "5" then press the OK button. You can then right or left arrow until you find the reset SP. Good Luck.
Oct 24, 2013 | Ricoh Aficio SP C410DN Laser Printer
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
How to remove user name and password richo mp 4500
go to sp mode by pressing reset 107 then press stop for a few seconds then inter copier sp then inter mode then search for clear user .......then press it then press execute then tern the machine off the on i hope that well help u
Nov 03, 2011 | Ricoh Aficio 450 Copier
Won't always transmit the fax.
what is the error code? the solution is to find the error code and what it means in the manual.
Oct 22, 2009 | Ricoh FAX3900L Plain Paper Laser
Lainer 5245 cs code 329-00
I believe that model is a Richo in a disguise.... To get into service mode, first press the yellow C/A botton, then the numbers 1 - 0 - 7, then press and Hold the red C/Stop botton for a few seconds and the display will change. Then you are in the Service Mode... Good Luck
Apr 18, 2009 | Lanier Office Equipment & Supplies
We have a RICHO fax 2050L been trying to ajust the time on the
Press "function", "6", then "2 2 2 2". Press "91" , "yes".
Now enter the new settings:
Use "*" , and "#" to toggle through months, and am/pm.
Press "yes" to lock settings.
Press "function" to exit
** Note: I believe, you will have to initially set the time to Dec. 31, 1999 @ 12:59pm, and wait for it to roll over to 2000, then go back and change the time/date to 2009.
Hope this helps.
Feb 25, 2009 | Ricoh 2050L Laser Fax
Ricoh FX-10 error code 2-21H
In the user guide, any code starting with "2-" is described only as "Possible fault in your machine." For more details, contact a Ricoh service technician.
Oct 20, 2008 | Ricoh Aficio FX10 Fax Laser Printer
Richo 3310 fax
To enter in to service mode press: "clear modes" ,107, "red cl " and hold the red btn for 30 sec
all in that order.
Aug 22, 2008 | Ricoh FAX5510NF Plain Paper Laser
Ricoh FAX3900L Plain Paper Laser Logo
213 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
