I have the same model Miele and ordered a replacement part. I have 2 Miele ovens side by side, and a door hinge on both ovens began to malfunction. I ordered and received the hinge , but when I started to install it, I found that the hinges were fine! The issue was that the 3 screws that hold the hinges to the oven frame came loose. One of them had fallen out on each of the doors, they had to be jiggled in order to close properly, which was not satisfactory. The ovens were installed 13 years ago by the original owners.
You will need to slide the oven out of its enclosed space and unscrew the sheet metal siding in order to gain access so that you can unhook the coil spring attached to hinge. I found that one of the small machine screws has fallen out on the 2 malfunctioning hinges. Once the spring is unhooked, you can align the hinge to screw it back in, and tighten the other screws that hold the door hinges. The screws on the other side has also become loose.
