Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
PowerShot SD300 New to this stuff but flash isnt going off at all. Taking pics outside works perfect or if there is enough light.....Just called Canon and they were not that helpful at all. Told me i can send in at my expense but probably would cost about $90 or more to fix and/or I can upgrade my camera (for models that are older than I can get for under $200....they want to offer them at $150). Anybody have an issue with the flash not going off? the only thing the canon buy told me is there might be a short in the camera. So when I asked if that was covered as not a user error...he is like no, 'force of nature issue'. Very disappointed with their service - may call back.
  • 10,594 Answers
You can set Flash function by pressing flash button on camera. Button has 3 type of settings, flash Auto, Force, Off. If you need further help, please go to flash function in user manual and if you need further help, post back here.
Regards,
Posted on Aug 28, 2008
Flash not working
Call canon and tell them you have a defective unit.
Mar 06, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
My canon powershot s3 IS is taking really dark pictures. The only decent pictures I can take with it are outside in sunlight. Pics indoors come out dark and grainy. I flip up the flash, but most of the...
This is not an answer. The S3 normally does not produce dark pictures, and I have seen this issue before. It has to do with a setting somewhere on that camera that needs to be adjusted. I wish I knew what that setting was/is as my wife's camera has recently started doing this ...
Jan 04, 2011 | Canon PowerShot S3 IS Digital Camera
Mode Selection Fault
Hi
Your mode position switch could just be damaged or the switch on the outside of the camera might not be properly lined up with the switch on the inside. You have to open up the camera body to see what I mean, its not hard, just make sure you take out the battery first.
If you need the mode switch, its pretty easy to take off, I just pulled one off an SD300 to see whats involved and its pretty simple.
As for international shipping... Im starting to do it more, but only via US Priority Mail International which is $12 for a flat rate envelope. I just don't like stuff disappearing during transport and that's why I don't like shipping to the other side of the globe.
If you need the parts please let me know, we will get the shipping figured out.
Good luck from: Darntoothysam com
Thomas
Jun 21, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
SD300 LCD Display Shows Same Image
Sounds like it needs service. Call Canon tech support.
May 28, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Focuses but never takes picture
Try a mode other than auto, and turn off the flash. Then try taking a picture. Did it work? If so, then your flash is either burned out, or the flash safety circuit thinks that the camera is open. If the flash is burned out, then professional repair is required, as a flash change-out is not trivial (Call 1-800-OK-CANON).
However, as mentioned it may be only a break in the safety circuit. Canon usually some of the screws in the camera case to serve as a means of detecting if the case is open (and thus disables the flash to prevent shock). Examine all the screws around the perimeter of your case. Are they all there and tight? If not, try moving and replacing any missing screws with one of the others that are still there.
May 26, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon powershot sd 300
Most likely your flash bulb burned out or was damaged. If you feel comfortable opening your camera you can buy a flash module on the internet or ebay for around $20-$25 and install it yourself. If you do so, be VERY careful NOT TO TOUCH the capacitor as those things can store a massive amount of voltage even when the battery is removed and the camera has been off for some time.
If you don't feel comfortable opening your camera and trying to replace it yourself, my suggestion would be to get a new camera. Repairs by Canon usually run more than $100 and the SD300 is a bit old to be laying out that kind of dough, in my opinion.
Mar 12, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon Powershot A75 Flash Problem
If it is a malfunctioning unit, you may qualify for an upgrade through Canon rather than going out and buying a new one, paying full price, you can get a deep discount through their loyalty program. Give them a call to set your camera up for service and the service technician once they have your camera will let you know if you qualify for the program and which camera you will qualify for and how much it will cost.
Hope this helps!
Mar 03, 2008 | Canon PowerShot A75 Digital Camera
Flash wont come on
If your flash is failing, it will require service by Canon.
Dec 24, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Powershot SD300 wont appear on computer
nothing on a sd300 but there is on a Ixus 40, see below for IXUS drivers and manuals http://software.canon-europe.com/products/0010105.asp
Sep 12, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
