Question about HP Pavilion a340n (DQ099AABA) PC Desktop
Main power cord
I unplugged ny pc the other day. When I plugged it back in my pc would not turn on. The green light in the back was flickering. I dont think its getting enoug power to turn it on.
  • HP Master
  • 5,568 Answers
I don't know how old your system is but what you describe sounds like a tired power supply. They will often fail after being turned off; they just don't start the necessary oscillations to continue.
These are not hard to replace but you will need to remove the current one to learn the ratings of the supply.
It only requires a Phillips screw driver to remove four screws holding the case in and then skin some knuckles pulling plugs.
If you are paranoid (not that there's anything wrong with that ;-) ), mark the connectors before pulling them so you have a 'guide' for plugging in the new one.
Power output will be on a label and the total wattage rating is the info you need; will read something like 350W or 450W.
The individual voltages and currents often listed are scaled up or down depending on the total power output so the total is all that is needed.
Very good supplies can be had for under $100 US and a typical commodity supply (kinda like the one that failed) can be had for as little as $10 +S&H on eBay.
Before the decay of the dollar, I bought these (350W) for $5.
They are repairable but . . .why?
These are the cheapest built part of your system and often the least reliable.
If you want one that will outlast your interest in the system, check out PC Power and Cooling.
Posted on Aug 28, 2008
I was removing the video card to tighten a nut. I unplugged the power cord and pushed in the power button to drain excess power, notice the solid green light went to flashing. I then removed video card to...
Open it up again. Take the video card out. Take the Ram out. Unplug the hard drive. Unplug the other drives. Unplug the network card(s). And unplug anything else that is tied to the motherboard. Now plug it all back in snugly.Finally,turn it on. It should be fixed.
Nov 23, 2010 | HP Pavilion a1330n (EL466AA) PC Desktop
I have an IBM T40 that worked great until yesterday. When I powered it up, the 4 lights (battery, etc) flickers but the laptop does not power up. I removed the battery, paused, tried with and without the...
There are a few things left you can try. First take the battery out and make sure the unit is unplugged. Next push the power button a few times to discharge any power inside the unit. Now put the battery back in and while plugging in the unit see if the charge light comes on or flickers at all.
If it flickers and goes out, you have a bad power cord or worse a bad jack on the laptop's main board. If it never comes on, you have a bad power cord or mainboard. The battery is probably dead (doesen't have a charge left in it.)
You said this happens regardless of if the battery is inserted. Have you tried powering up the unit with no battery installed and just the power plug?
I'd see about gettting a replacement cord first. If that doesen't do it you probably have a bad board.
Oct 17, 2010 | Computers & Internet
Compaq presario sr2020nx will not turn on
Just check the power suply behind computer case , or check your cable power.
May 24, 2010 | HP Compaq Presario SR2020NX PC Desktop
Flickering green light on power supply
power units not working,, the light means power problem you will need to replace the power supplie
Apr 23, 2009 | Computers & Internet
HP Laptop Seem to Charge but Wont Turn On
When you plugged the power cord back in did the green light on the power cord battery light up. How long have you had the cord. Make sure the power cord is working properly.
Jan 03, 2009 | HP Compaq Presario C304NR Notebook
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Computer Startup Problem
you can try unplug the pc open the case and take out the power supply connection from the mother board wait a while and put it back in and try another power outlet and try it on a ups if u have one. or try unplugging all the components at the back of the pc connecting back only the mouse,keyboard and monitor and try it. then, if that does not work try removing the cpu and place it firmly back into the slot or socket also the memory. GOOD LUCK!!
Jul 02, 2008 | Gateway 506GR PC Desktop
HP Pavilion a340n (DQ099AABA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
