When trying to print from e mails i get error code 0 script error...all other printing tasks work...what can i do?
  • 09er Aug 29, 2008
    Thank you very much zukirider tried your solution and two mins later was printing e mails...brilliant thanks again 09er
  • 300 Answers
You can try this:
Click Start then Run and enter the following:
regsvr32 ole32.dll
Click OK.
Thanks
Posted on Aug 28, 2008
  • S C Aug 29, 2008
    Your welcome. Glad I could help.
When trying to print online the error is about scripts
First I would suggest that you re0install your browser. The when you want to print a webpage just press "ctrl" and "p" at the same time.
Apr 12, 2013 | Dell Computers & Internet
Earlier it was printing ok but now it is not printing.
Yes you would create an on change event that runs a print and delete and select commands.
In vba of sheet1 enter this code change in code a4 and sheets (1) as necessary I tested and works so if problem its put in wrong place.
If you change it note I didn't insert an error handling script so you may need escape or control + break to stop loop. For instance if you don't delete the value thats to be greater then 0 every delete will create an on change event and loop.
Private Sub Worksheet_Change(ByVal Target As Range)
If Range("a4") > 0 Then
Sheets(1).PrintOut
Range("a4").Delete
Range("a4").Select
End If
May 17, 2011 | Computers & Internet
My Dell V715 W does not print web page I get this scrip error. An error has occured in the scrip on this page line;2036 char;1 error; the server threw an exception code; 0 URL:...
Hi Louis,
If this is constantly happening for a single page you maywant to disable debugging.. In your browser goto; · Tools>Internet Options>Advanced Tab · Check Disable Script Debugging (InternetExplorer) · Check Disable Script Debugging (Other browser) · Click Apply · Click OK If this doesn't work try the following.
Make sure your browser is the most recentversion (check for updates is normally under the help menu)
Try deleting temporary internet files from thecache. Depending on the browser you are using the location of where to do thiswill change.
Mar 01, 2011 | Computers & Internet
Windows 7 cannot print email. An error message comes up as follows Line 1507 Char 1 Error invalid argument Code 0 URL res/ieframe.dll/prieview.is
You didn't say what e-mail you are using but from the error message it looks like you are trying to print from within frames. Are you using the print button inside the email or the print in the browser window? Try using the print button inside the email program not "file, print" or a print button on the browser toolbar.
Jul 06, 2010 | Dell Computers & Internet
Printer not activated-error code 30
Sometimes, you may get printer not activated - error code 30 when you try to print using your printer. It may occur when you try to print a PDF document. Sometimes, your Antivirus scripts block you from generating the document and you may have to face this issue. If you have installed Antivirus software and you have encountered "Printer not activated" error, you need to disable script blocking. If this does not resolve the issue or you do not have installed Antivirus, you need to change the Calyx Document Converter printer settings. If it also doesn't work, you need to reinstall the printer driver in your system.
Jul 12, 2009 | Cannon Office Equipment & Supplies
Prints java script instead of highlighted page
First, you probably should not stop the printer after it starts printing, it always creates problems. Second, you should clear your browser history and then you should select the range of pages to print on your print properties menu. If this does not work try reinstalling the print drivers.
Dec 13, 2008 | Brother MFC-210 All-In-1 Print/...
Installing to second computer
Hi Cathy, script errors fall into the (Software did not install correctly issue, most common). Uninstall the printer software from the notebook. Than go to the link below & download this registry cleaner.
(Its free).
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
Once finished restart your notebook. Install the Lexmark software from the CD or download it from Lexmark, there (may) be some updating within the downloaded software. http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:463:0:0
Click the above link. Pick your operating system & the link to download will open.
Good luck Cathy!
Mike
Oct 03, 2008 | Lexmark X7170 All-In-One InkJet Printer
Printing
your probably printing from internet explorer/website?
on internet explorer go to tools -> internet options-> advance tab
and check "disable script debuging"
thanks for rating
Jan 11, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
