Question about HP Photosmart C6180 All-In-One InkJet Printer
Photo ink cartridge
How do you load the photo ink cartridge in the HP Photosmart C3140 all in one printer scanner copier?
  • Anonymous Aug 31, 2008
    maginta is no working
  • 40 Answers
Remove the black ink cartridge and insert the PHOTO cartrdige to the black ink slot and im pretty sure that it will perfectly work...
Posted on Aug 31, 2008
Says in quire bur won"t print
HP typical junk and user error problem . check all connections align paper check ink cartridges. check if hp will assist from they're technical support page.
Aug 21, 2013 | HP PhotoSmart C3140 All-In-One InkJet...
Where is the ink cartridge located on the HP c3140 and how to I get to it?
From the manual:
Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
Chapter 1
14 HP Photosmart C3100 All-in-One series
HP All-in-One overview
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridge
Jul 24, 2011 | HP PhotoSmart C3140 All-In-One InkJet...
My printer HP Photosmart C3140 prints but nothing prints. What seems to be the problem?
Check the ink cartridge levels to make sure you can print, the manual will guide you through the procedure if you are not sure.
Jan 01, 2011 | Office Equipment & Supplies
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
Installed updates now HP printer won't accept refilled ink
HP does not recommend refilling thier tanks, their print heads are built in to the cartridge so if you refilled it before resetting the tanks you will have to go to www.hp.com and run the trouble shooting tool for free to fix your issue. you may have to replace the catridge.
Mar 11, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
I have a HP Photosmart C3140 printer. The problem
I had a similar problem with a HP printer some years ago. What I did was to shut the power off, open the cover and, using a clean, wet rag, wipe the steel rod that the ink cartridge slides along. It get sticky with ink residue and paper dust. Wipe all sides and dry it with another clean rag. (I think I used paper towels). Then slide the ink cartridge holder over to the other side and clean the other half of the rod.
Dec 20, 2017 | HP PhotoSmart C3140 All-In-One InkJet...
I just bought a hp photosmart c3140 tri-color cartridge. after 8 small prints the ink low level lights flash-rendering my printer unusuable. i re-fill the tri-color, and reset the printer. still the...
I would be taking it back to the place of purchase and asking them to replace it. Or contacting HP directly with the problem.
You can contact HP via their home page of their website, or use the link below for troubleshooting and support:
http://welcome.hp.com/country/au/en/support.html
NOTEs:
1. Unless you are printing a final copy of an item it is a good idea to always print in Draft Quality (to save your ink). HP Printers allow you to do this. This setting is generally within the Print window, when you select Print.
2. When you are printing a final copy then switch from DRAFT to BEST quality.
Feb 10, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Ink cartridge
Black HP 92
Color HP 93
Photo HP 99
Jan 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
118 people viewed this question
Ben Johnson
