Question about HP Computers & Internet
Computer's modem is being blocked from connecting
Check your default gateway on your local area connections. it must match ur modems ip...
Posted on Aug 28, 2008
How to connect pc to thinkland
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
Disconnect ALL cables from the modem and routericon1.png: internet cable, power, (and ethernet). You can leave the computers on, but if this doesn't work , try it with the computers off.
Connect the modem, cableicon1.png, ethernet, and power. modem .
Connect power on router, Wait until router has a connection
then connect ethernet from modem,
then one by one connect the computer ethernet lines to the router.
Feb 07, 2014 | Computers & Internet
Hello!. The day before I blocked my computer ip in wireless lite N ADSL2+ modem router (but I am not sure I blocked it or not). And the day after computer wireless cannot connect to the internet. I cannot...
I am not familiar with this router but there is usually a reset button on it which puts it right again. Do you have a manual?
Otherwise go online to the supplier of the modem.
Nov 02, 2017 | D-Link Express EtherNetwork DI-604 Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    I need to setup my motorola SB5100 cable modem to accept remote desktop connections. can anyone help?
    by defualt it should be able already- you may want to check your computer and make sure there are no firewalls blocking you.
    May 13, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
    M t u
    In computer networking, the term Maximum Transmission Unit (MTU) refers to the size (in bytes) of the largest packet that a given layer of a communications protocol can pass onwards.
    MTU parameters usually appear in association with a communications interface (NIC, serial port, etc.).
    The MTU may be fixed by standards (as is the case with Ethernet) or decided at connect time (as is usually the case with point-to-point serial links).
    A higher MTU brings higher bandwidth efficiency. However, large packets can block a slow interface for some time, increasing the lag on other packets. For example, a 1,500-byte packet, the largest allowed by Ethernet (and most of the Internet), would block up a 14.4k modem for about one second.
    The default MTU on a PPPoE connection is 1,492. The default MTU for a DHCP or PPPoA connection is 1,500.
    Increasing the MTU size beyond these levels is possible on a client computer, but not recommended, because the MTU size on the outbound connection to the ISP will nullify any potential gains from a larger MTU.
    Apr 20, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
    FIREWALL ON P2P
    There is no firewall in this modem, it's just a modem working in bridged mode. So the problem is in your router (firewall or port forwarding) or the firewall on your computers.
    Sep 25, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
    Computers & Internet Logo
    78 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
