Question about Linksys Wireless-G WRT54G Router
Wireless Printer set up
I'm setting up my new Lexmark wifi wireless printer and have followed all the steps unti it gets to the enter a "network key" page. I have no clue what my key is i originally used.
  • 148 Answers
If you login to your router you should be able to display it in the LAN section of your software
Posted on Aug 29, 2008
Hello. pls let me know how to restore my lexmark x6500 wifi printer??
To restore your Lexmark X6500 Series printer to its factory default settings, follow the steps below:
  1. Press the Settings button on the printer operator panel.
  2. Use the arrow keys to move through the selections until Defaults is displayed. Press the check mark button to accept this option.
  3. Use the arrow keys to move through the selections until Set Defaults is displayed. Press the check mark button to accept this option.
  4. Use the arrow keys to move through the selections until Use Factory is displayed. Press the check mark button to accept this option.
  5. Use the arrow keys to move to the required country, language, date & time, time format, fax number and fax name and press the check mark to confirm each selection.
  6. When the process is complete, the display will read Initial Setup Complete.
Source: How to Reset a Lexmark X6500 Series Printer to the Factory Defaults
To reset the printer's wireless network settings, please refer to this article: How to Reset the Network Settings on the X6570 Series AIO Inkjet Printer
Jul 27, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
ORANGE WIFI LIGHT IS ON
The orange WiFi light on the printer indicates that the printer is not connected to any network or trying to get connected to a wireless network when it's blinking.
Execute the Lexmark Wireless Setup Utility and make sure to enter the correct encryption keys if your wireless network is secured.
Make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
Place your printer where it receives excellent wireless signal quality and away from other electronic devices which can cause wireless interferences (e.g. cordless phones, microwave ovens, baby monitors, garage door openers, and other wireless electronics).
Jul 26, 2011 | Lexmark X6570 InkJet Printer
I want to connect to a new router but the orange wifi light is on and re installing software does nothing
Try to reset the printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Adapter to Defaults. Once done, re-launch the Wireless Setup Utility in Lexmark Printer Home application. Follow the instructions on your computer screen. Make sure you enter the correct encryption code if your wireless network is secured. Also, allow full access to all Lexmark printer communication and processes in the program rules/permissions for your firewall.
Jun 19, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My printer is connected to another wireless network which is not the same as my laptop how do i connect it to the right one?
I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable.
Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
May 23, 2011 | Lexmark X4650 InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
My lexmark z1420 has been in the loft for some time, I have switched it n anf the wi-fi light keeps flashing orange no green?
Try to print the wireless settings page to determine if your printer is still on the same wireless network as your router and computer. To print the page, follow the steps in these article on How to Print the Network Settings Page on the Z1400 & Z1500 Series Inkjet Printer; a brief explanation of its values. On the page, check the Status, SSID and also the IP address and see if it's connected to your network. Otherwise, you may need to reset your Lexmark Z1420's wireless network adapter and reconfigure it. To reset, follow the steps in this article on How to Reset the Z1400 and Z1500 Series Network Settings. Launch the Lexmark wireless setup utility to reconfigure the printer to your wireless network.
Hope this helps.
Jan 07, 2011 | Lexmark Z1420 Printer
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
I have a lexmark x4690 wireless printer. I had to change my bell sympatico dsl router. Now I need to change the network on my printer but I can't. I no longer have the driver cd and I tryed downloading...
You will need to reset the printer's wireless network adapter then reconfigure it with your new wireless network settings. On the printer's operator panel, press Setup button > Network Setup > Reset Network Adapter > hit Ok. The Wifi light will momentarily turn off then will turn on orange. Once you have that, run the Lexmark wireless setup utility on your computer to configure the printer with your new wireless network settings. Thanks.
Aug 04, 2010 | Lexmark X4690 Wireless InkJet Printer
New epson Printer with WIFI asking for the PIN
You mean the wireless network key?
To get your wireless network key, do the following steps:
1. Open Internet Explorer, on the address bar type 192.168.1.1
2. There's no username and type admin on the password. If admin didn't work, use your own password.
3. When you have the Setup Page open, click on Wireless Tab, then click on the sub-tab Wireless Security.
4. There you can see the Security Mode. If the mode is set to WEP, the WEP Key 1 is your wireless key. If the mode is set to the WPA-Personal, the Passphrase or the WPA Shared Key is your wireless key/PIN.
Dec 02, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
77 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
