Question about Brother ML-100 Typewriter
Typewriter is an ML100 Standard Brothers Typewriter
I'm using an 86TL Universal Lift-Off Tape. The answer given does not seem to apply. I'm having trouble inserting this correction tape.
  • Anonymous Nov 03, 2008
    the insert ribbion seems to not go in correct. Could you please send a reason for this
    Scholar:
  • 183 Answers
Repost if you are still having this problem
Posted on Nov 01, 2008
INSTALLING CORRECTION TAPE ON A BROTHER SX4000 TYPEWRITER
try to see it in the sides or it might be in the bottom of the machine in some models remove the older and replace the newer.
Aug 25, 2008 | Brother SX-4000 Typewriter
Supplies - Correction tape replacement
It takes a Nukote B199 or a Gen. Ribbon T333C Ribbon and a Nukots 86TL or Gen . Ribbon T355.
We have them in stock.
DickyO
216-241-0027
Mar 18, 2011 | Brother ML-100 Typewriter
Brother ml100 standard - eraser tape will not erase, nor will it rotate to more tape. There is sufficient tape on the roll. Thank you
do you have it past the leader ( the red part)? there is a sticky place just before the actual corr. tape starts. you need to pull this loose before you put the tape on. it should turn counter clock wise. the tape should all be on the round spool, not the spool with the knob. if this info doesn't help - let me know. never seen the corr. tape stick so that you can't turn it by hand.
Dec 24, 2010 | Brother ML-100 Typewriter
How can I get printer ribbons for this Brother ML 100 typewriter? Can you give me the code #?
The Brother ML100 uses the BRT 1030. There are several supplies available like the lift off tape, the daisy wheel and of course the printing cassette.
check it out:
Brother ML100 Typewriter Supplies
Good luck and if you need anything you can always call or email.
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082 8 to 5 (pst) Mon-Fri
Sep 15, 2009 | Brother ML-100 Typewriter
Installing correction tape
The full spool goes on the L. side of the printer it goes thru guides on both sides of the printer and thr empty goes on the R.
Be sure the dull side of the tape faces the paper.
DickyO
Aug 28, 2008 | Brother ML-100 Typewriter
Brother ML100 Typewriter:All of the sudden, it just won't type. It seems the 'hammer' doesn't hit the daisywheel. We've replaced the daisywheel, corrective tape, ribbon and still it goes through the...
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Nov 14, 2007 | Office Equipment & Supplies
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Brother ML-100 Typewriter Logo
143 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
