Question about Creative Labs ZEN V Plus MP3 Player
My ipod is facing with Rebuilding library
Sir,
i have a ipod of zen v plus series of 1 gb.I was happy with it's function & flexibility of working
the problem bean when it was accidently fell on to floor of water after that i dryed with my dryer and then it was alright i had listen to 2 songsafter that it was stuck with Re-building Library ant it stayed untill the battery was drained.I am facing this problem from one month i could find any solution kindly plaese help me
Please post the solution on e-mail
irfan_khan065@yahoo.com
Thank's
I am having the same problem, although with mine I just went too long before charging it, I have tried the reset button but it does not work, just goes straight to Rebuilding Library.
And sir, it is a Creative Labs MP3 player, not an iPod, iPods are Apple products
Posted on Sep 06, 2010
    Scholar:
  • 62 Answers
When you dried it off with a drier did you have the unit completely appart at the time? It sounds like you might not have dried off all the water. If you don't get all the water out it will stay there for a long time causing problems, and after that you'll end up with corrosion at which point the unit becomes virtually garbage. Also, one other thing to remember is the danger of too much heat. If you applied too much heat with the drier it could have damaged the electronics. At this point I would take the unit appart and blow it out with some pressurised air, then stick a new battery in and do a hardware reset if it allows for it in the software menu. It might even have a tiny reset hole on the outside.
Posted on Aug 28, 2008
Zen V-Plus freeze at rebuilding directories
YOUR MUSIC FILE IS CORRUPTED.When you hook it up to pc .open the files on the zen and format the music file.If you still have a problem.Format the drive and download new drivers here>http://support.creative.com/kb/ShowArticle.aspx?sid=8451.RICHARDM69
Dec 10, 2008 | Creative Labs Zen Neeon MP3 Player
Zen v plus 8g
If you already try both reset, then try doing a firmware update.
On computer try unplugging computer power cable, and if it is a laptop also remove battery, this sort out problems related with electrostatic charges on computer USB ports.
Sep 14, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen v plus 8g
Try resetting it by inserting a paperclip into the reset hole on the side of the player, just under the on/off switch
Sep 13, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen V plus can't detect by the computer & all the data base losts
Suggestion: uninstall the failed portable device in Device Manager.
Note: You should already have the application for your portable device installed on your computer before continuing.
1. Go to Device Manager and make sure that your portable device is not reporting any problem. If it is, uninstall it.
2. Reconnect your portable device. The computer should detect it now.
Jul 07, 2008 | Creative Labs ZEN V Plus MP3 Player
Mp3 stuck in rebuilding library mode
hello guys sorry to hear your problems i have same problems too. Ok first plug ur zen player (mines V PLUS.. heheh) to ur pc then hold play button then keep pressing the reset botton until it turns on RECOVERY MODE then select YES to all (clean up, format, reload firmware) then download the RECOVRY TOOLS at creative site install it then plug ur zen player and run the recovery tools (cross ur finger) hopes it works mine a big smile hehehe email me at oracle101rage@gmail.com if it works..Gud Luck guys
May 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Re-building library
Replace hard drive
http://www.hardwarezone.com/articles/view.php?cid=9&id=1331
Apr 14, 2008 | Creative Labs ZEN V Plus MP3 Player
Stopped at "rebuuilding library"
first try the reset, if that does not work
look at this video
thanks for rating
Jan 11, 2008 | Creative Labs ZEN V Plus MP3 Player
Frozen
if it keeps on rebuilding the library the disk had a bad spot on it try going in to recover mode and do a clean if that doesn't work do a format if that doesn't work download the latest firmware if that doesn't fix you will need a new hard drive or flash drive.
Nov 15, 2007 | Creative Labs Zen Micro MP3 Player
Not rebuilding Library all the way
1. Press and hold the Play button while powering on your player.
2. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Oct 27, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
76 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
