Hyundai Motor 1998 Accent Logo
Posted on Aug 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hyundai accent 1.3 manual 1998
Going through gears car doesn't catch, as if it was sitting in neutral.
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on Aug 28, 2008
Anonymous
Expert
Level 2:
Answers
71
Questions
Helped
19557
Points
138
Id say your linkage in the engine bay has disconnected at the gear box....ie the bars that run from your gear stick right under the car to the gearbox
My 1998 hyundai elantra will not go in reverse...any ideas?
Hyundai Elantra transmission won t go into reverse m ...
www.fixya.com > ... > Cars & Trucks > Hyundai
Hyundai Elantra cars & trucks transmission won t go into reverse m ... Question about 1998 Elantra. 1 Answer · Reverse gear almost dead in 1998 Lantra auto.
99 accent wont go into reverse - Hyundai Forums : Hyundai Forum
www.hyundai-forums.com/...accent/157948-99-accent-wont-go-into-rev...
Mar 28, 2013 - 3 posts - ‎3 authors
Here is my situation and am hoping I might get somebody who can actually help me with this. I have a 99 hyundai accent automatic with ... 2001 Accent No Reverse
Apr 10, 2011
1998 Hyundai Accent Automatic Trans Problem ...
Dec 6, 2005
More results from www.hyundai-forums.com
Why is it having trouble moving in reverse?
Hyundai accent manual transmission
Your synchronization rings are worn out. These rings and responsible for bringing the lay shaft and drive shaft to the same speed so gears can mash easily.
Hi, problem is that i face no engine start although the ignition goes on, and when i put the car on neutral it also goes off and engine goes off, the car is hyuondai accent 1997 hutchback,manual gear 1.5 l...
Hard to tell, I dont fully understand what you have written as your problem. i.e. no engine start or the car will not move when the engine is on and you put it in gear and release the clutch
Hyundai Accent 2000 manual transmission : I seem to have lost the ability to shift into 2nd, 4th, and R. I have disconnected the appropriate rods and have attempted manipulating the linkage manually. The...
Did you run over some kind of object, such as a curb, a tree limb, or debris from an accident, or hit a deep chuck hole in a road? I think you bent the linkage rods. You might have to get replacements, maybe even at a do-it-yourself auto salvage yard.
3helpful
Transmission: Reverse
check power going to reverse shift solynoid and check neutral switch
3helpful
3answers
1998 Hyundai Accent clutch pedal travel
dear friend-you can bleed the clutch.im am sure this will solve you problem
3answers
Hyundai Accent losing power when hot
sometimes loss of power can be caused by a clogged catalytic converter which can make the car at times hesitate, and about the trasmission maybe the governor on it might be faulty what that does it changes the gears when it reaches certain speed
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
