Question about Minolta Office Equipment & Supplies
I need to find the IP address but I don't know how
  • 446 Answers
Go to start - run - type cmd then enter
under the command prompt type ipconfig/all then enter
from there you can see all your IP's
Posted on Aug 28, 2008
Lost ip address
They most likely mean serial number.
An IP address is issued by a router and can change from time to time when you connect to the router.
May 17, 2013 | Sony Cyber-shot DSC-T90 Digital Camera
I'm using ricoh aficio 2045e, it's not printing! I think because I don't have the hostname or the ip address and I don't know from where to get it?
Enter in SP mode and print the ALL SMC report .In this report find the IP adress.Enter in your PC printer device the IP adress.
Feb 17, 2013 | Ricoh Aficio 2045e 2035e Copier...
IP Address Conflict... So I have two computers at home. Two Dell Desktop computers running Windows XP. Both have USB wireless network adapters. I don't own internet (Don't shun me. My fam...
although I don't support IP Pirates(if they can afford not to be). there is one trick that may help but not if the security on the router is strong as they can set it to only hand out 1 number. However if you know the IP( that is being handed out. then you can manually set the wireless adapter on the second system to have an IP that is +1( (instead of a DHCP setting)of the number you are given. make sure the gateway and subnet mask is exactly as is handed out to the first system.
you can easily view this info. from a command prompt and typing:ipconfig /all
hope this helps
Don't forget to vote for me
Thank You
Aug 17, 2011 | Dell Inspiron 530s Desktop Computer
We are trying to download the drivers for a network but it is asking for the IP address IPv4 and we don't have it. Could you provide it.
well check your printer machine IP address...just like a computer printer machine have their own IP.then use the IP of you printer...
Jul 21, 2011 | Panasonic Workio DP-190 Multifunction...
My hp mini will not obtain any ip addresses and i don't know what to do. i need help fast!
hi ' it does need to set it as obtain , but if you want to create an IP address click start botton-click control panel-click my network connection open network connection then right click - --- -- then click properties then type the address what you want then click sub mask and press apply/ok.
Jul 12, 2011 | HP Mini 1010NR Notebook
Don't know ip address to get it running gateway computer
If, you are looking for the localhost IP address by default it is
If, you wondering what is your IP address when connected to the internet, go to it will provide it for you.
Jul 06, 2011 | Computers & Internet
Dear Sir,need ip address
i want to configure a network printer on lan but i do not know how to assign an ip address to the printer panasonic dp-8016p
Dec 20, 2009 | Panasonic Workio DP-1820P Laser Printer
Putting right the ip address ?
Before you proceed you need to know the static IP, Subnet Mask and Gateway address for this printer. Once you have them: -Enter the menu mode by pressing the + button -Press the + button till you come to the Network Menu. -Press the Enter button. You should now see TCP/IP. Make sure it says Enabled which is the default setting. -Press the + button till you come to IP address then press the Enter button. - IP addresses (for now) consist of four octets or four groupings of three numbers such as in this example **. Using the + or - buttons (+ counts up 0,1,2,3?.; - counts down 255,254,253?..) you are going to set the number of the first octet or in the case of the example *192*. Once you?ve set it correctly hit the Enter button. -Do the same for the other three octets. Hitting the Enter button after setting the fourth octet will set the new IP and take you back to the TCP/IP menu. - Press the + button till you see Subnet Mask and press the enter button. - Just like the IP address the Subnet Mast consists of four octets. Set the value to you needs just as you did with the IP address. Again when you hit the enter button after setting the fourth octet you will be taken back to the TCP/IP menu. - Again press the + button till you come to Gateway Address and hit enter. Enter the Gateway IP address exactly like you did when setting the IP address. Don?t forget to hit the enter button to set the address. You should now be at the TCP/IP menu again. -To exit the menu press the On-line button on the printer. Your printer should now be configured with you IP address, subnet mask and gateway address. As an added check I would go back into the menu by pressing the + button, going into the Information Menu and printing selecting the Print Menu Map option. Verify the setting we just made with what is printed out at the top of the page. If everything matches you?re ready to go! Let us know how it goes and please don?t forget to rate this posting.
Jan 22, 2007 | OKI C5100n Laser Printer
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if don´t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
