Question about Canon NP 6650II Copier
Canon gp 200 error code EO10
HELLO SIR I AM GETTING ERROR CODE EO1O ON MY MASHENE IT GOSE 20 COPIES ALL RIGHT THEN IT APPERS CODE AND PAPER JAMS AT DRUM AND ERROR CODE COMS AND COPIER GOES VERY SLOW IAM FD UP WITH THIS PROBLUM PLESE HELP I AM VERY GREAT FUL TO YOU THANK YOU
  • SIGMALAZ Aug 29, 2008
    aaaaaaaaaaaa
  • 168 Answers
That is a main motor drive error code either you have a bad motor or something is locking up
Posted on Dec 08, 2008
Hello Sir, I have Canon IR 3530 Machine, it is not work properly when i am trying to Photocopy of document but when i am taking documents copy than it is not possible for me. My machine becoming very hot...
as I understood, your copier is getting paper jams and heats too much.
The problem can be in the fixing heater. Probably he is heating too much, but in this case you would get error code like E001.
You better call service this problem is hard to resolve by this way...
Aug 23, 2011 | Canon Office Equipment & Supplies
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Apr 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I have a canon gp200 copier. while getting a photocopy one side of the document get lightened. can you suggest me to solve the problem.
Hello sir; I would like you go to clean up the charge and discharge corona wire ( right under the drum unit on the machine) with alcohal and Q-tip.
Jan 10, 2010 | Canon GP-200 All-In-One Printer
Copy turns on but unable to make copy
Hello sir;Check the paper tray, pull out paper tray may be have a paper hanging there.
Jun 13, 2009 | Canon PC-920 Black and White Copier
False jamming at duplex unit
Sounds to me like a paper jam switch has either become dislodged, or malfunctioned...you'll need a tech.
Feb 21, 2009 | Canon NP 6050 Copier
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
CanonPC6RE
I don't know if this addresses your problem, but check this link. If Canon has not already repaired your unit (since September 2006), they may help you out.
May 15, 2008 | Canon IMAGERUNNER 6570 Copier
Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Mar 15, 2008 | Office Equipment & Supplies
Canon NP 6650II Copier Logo
140 people viewed this question
old marine
old marine
