Question about Lexmark X125 All-In-One InkJet Printer
Calls to my home is pickup by fax - Lexmark X125 All-In-One InkJet Printer
  • 397 Answers
Here is a link to a pdf file version of your instruction manual:
You will need a pdf reader like acrobat reader or foxit reader to be able to view this file.
You need to change the number of rings before the fax machine answers your phone in order for you to answer the phone first, if you don't use the fax part of your machine simply unplug it from the telephone socket.
Posted on Aug 28, 2008
Dell 2135CN cuts-off incoming calls to my home phone number after 2 rings and the call goes to the printer. I hear the ringer inside printer, then hear fax tones, even though the call is not a fax. My...
Hi and welcome to FixYa!
Well if that's the case, the printer should be detached or powered of during call operations. The printer detects incoming calls that's why it triggers it to operate. Turning it off during operation will surely be the solution.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 05, 2011 | Computers & Internet
Call Pickup
It is a wiring problem i would consider calling the manufacture and see what they can say.
Jun 12, 2008 | Brother IntelliFax-2820 Laser Fax
I want to shut off answering machine
Use the Reception Mode button to set appropriate answering mode - press it repeatedly until a small arrow on the display will point to the desired option:
"TAD" - is the one you are using now, when the answering machine picks up the calls.
"TEL" - is the setting when no automatic pickup occurs, you always have to pick up the call and either talk (if there's a person on the other side), or press START to receive a fax (when you hear the fax beeps on the other side).
"FAX" - is the setting when after four rings the fax will pick the call up automatically (no answering machine). If you pick up the call manually after 1-2-3 rings (before the automatic pickup) you can either talk or START fax reception.
It's good to check from time to time if the reception mode is as you want it, it's easy to change it by mistake.
Good luck and come back with a testimonial if helped :)
Jan 31, 2010 | Sharp UX 460 Plain Paper Thermal transfer...
Not picking up calls, not sure if my son has pressed something or there is a fault with the machine.
Look at the display. On the right there is a 3-character mode indicator. It can be:
MAN - manual pickup
FAX - automatic pickup, only fax will try to "speak" to the other side
F/T - automatic pickup, device will signal if there's no fax signal on the other side, only someone trying to speak
TAD - Telephone Answering Device
Press the "MODE" button several times and see how the display cycles through these options; just press it repeatedly until the one you want to use appears.
If however the device is set to something else than MAN and still doesn't pick up calls, then it indeed might be faulty.
Oct 28, 2009 | Brother FAX 930 All-In-One Thermal Printer
May fax wount pickup call,i can send out but i can't get in fax
chk the tel/fax switch on the menu button if it is set to tel only, the fax will not pick up a call
Oct 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Help I have a Lexmark all in one x7675 which I have been using without problems wirelessly. I am trying to use my home phone number as a fax connected to the printer. It seems to work if I ring it from my...
When you ring it from your biz line, does it pick up? If you're using a high speed dsl line, you'll need to put the machine where a normal phone would go. You should be able to ring the machine using our cell phone. If the machine indicates an incoming call, but still doesn't pick up, check the settings and make sure it isn't set to manual instead of automatic fax pickup.
Apr 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Fax answers on phone calls.
Hello There. Most household all in one units cannot operate on the ring characteristcs that you are describing.
They simply operate on the number of rings before automatic pickup to the fax machine. Therefore, you will need to just change the number of rings before the fax machine picks up. In this case however, you will not be able to use voicemail, since one or the other will will pickup.
Page 63 and 64 (in PDF) or page 62 and 63 (hardcopy manual) explain the process.
Ignore the information about setting higher then voicemail. That information is typically only valid if you have the old voicemail devices in your home. Most people now adays get a voicemail service added to your telephone service, in which case you cannot control the voicemail as easily.
So again, in other words you will be sacrificing your voicemail for your fax machine. Only other way around it is to get a dedicated fax line to seperate the two numbers.
Feb 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
Brother intellifax 4750 does not answer with FAX signal
Make sure that it is set to fax mode not to phone mode
Jan 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Message bank
Look through your fax machine instructions,. There should be some there regarding how many rings before pickup. Or maybe the unit does not have that feature and is designed to have its own separate line for faxes.
Sep 21, 2017 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark X125 All-In-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
