Question about Samsung HP-S5053 Television
SAMSUNG HPS5053 PLASMA TV
I NEED HELP WITH THIS TV, IT GETS HAVE OF THE PICTURE WHEN IT WARMS UP.CAN YOU HELP ME
  • ESTEBAN MERINO
    ESTEBAN MERINO Oct 01, 2008
    i posted this myself, but i forgot to add that i solved the problem.
    loose connections on the power supply board.
SOURCE: we have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Posted on Oct 24, 2008
robwan
  • 20 Answers
SOURCE: Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Posted on Nov 01, 2008
  • 98 Answers
SOURCE: sumsung hps5053 would not turn on
Samsung manufacture warranty is 2 years.
Posted on Feb 06, 2009
toolkits
  • 1099 Answers
SOURCE: Samsung 58" plasma pop spark no picture
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on Jul 02, 2010
SOURCE: samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle. Source(s): I just fixed my TV!!!!!!!!
Posted on Mar 17, 2011
When the Samsung 50" plasma TV is turned on and during the whole time the TV is running there is one small green dot (or light) in around the middle of the screen. It continues and does not go away as the...
Still under warrenty?Yes,call the tv manufacture,get this tv replaced quickly.The Plasma screen is developing a burn in dead pixels.This problems,can't not be repair.Except replaced the Plasma screen itself.The plasma screen panel are 90% of the tvs,not worth repairing,if it damages or broken.Will cost the same as a new tv,if the screen require replacing.Still under warrenty call it in right away to get the picture screen replaced under warrenty.
Oct 04, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
My 50'' Samsung Plasma has dead screen after only 2 years
welcome to fixya!
without doing voltage checks, my best guess is this:
Plasma hpr5053 or hps5053 models will burn out a buffer board or both, there are two buffers and the Y board.
I usually change all 3 at once, but if on a budget you can try to remove one buffer and see if you get half picture (upper or lower)
this is something only a technician should attempt. the boards cost $200 each (buffers)
$300-$400 (Y board).
if you actually get half a picture the Y and one buffer are good, a bad buffer usually burns out the Y board. and in really bad cases the panel is bad also (not common, but possible)
For part#s , specific help you can post a model# , but again this is a repairmans job not something the average customer can fix.
hope this helps
Eric
Aug 27, 2009 | Televison & Video
Samsung HP5053X Colored static
sounds like either an HPS5053 or HPR5053 both have adjustment controls on the Y board that should clear the spots.you will need to remove the back and mark the adjsuters postion with a sharpy , then with a picture turn these tiny controls to a midpoint with less dots/spots.
the Y board is left side facing the back of set. the controls are the lower two, s6001 or 6002 I think
Jul 22, 2009 | Televison & Video
Bottom half of picture cuts out?
This is most likely a "cold" solder joint on one of the components, i.e. capacitor, inductor, ect. If you are handy with a solderiing iron and disassembly and more important reassembly, then you could reflow the cold joints. I hope this helps. Good luck :)
Jun 16, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
SVA 42" plasma
bought a new power supply / board and had it installed. Has worked for 9 months, but now the screen goes black after it warms up, still gets the sound, just no picture. The tech that replaced the board told me that type of TV get extremely hot and it fry's the components.
Dec 23, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Samsung HDTV HPS5053 - Picture snow?
sounds like a diffusion problem, if the tv is still inwarranty call 1-800-SAMSUNG, it needs a voltage adjustment
Sep 06, 2008 | Televison & Video
Samsung HPS5053 Plasma TV
It may due to the Logic board, or Logic Scan board, or the Panel failure.
Apr 19, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Image is grainy whenever tv is cold
try having the v_set and v_scan voltages reset 15vdc lower..
Nov 02, 2007 | Samsung HP-S5053 Television
Televison & Video Logo
50 people viewed this question
Jerry Greenberg
Jerry Greenberg
