Question about Reddy Heater-30-55,000 BTU Variable
Won't fire up
I have a ready heater 55,000. When I plug it in, it runs and what seems like a fog comes out the front, but it won't ignite. After a short bit it turns off. I have put in a new plug.
  • silvercliff_ Sep 07, 2008
    Thanks tbugger
    I tore down the unit and went over it. I don't have any spark. I checked the the plug lead with my electric meter and had no current.
    I called DESA and they said I needed a new igniter. The price was $100 bucks, which is about half the cost of a brand new heater.
    My heater is about ten years old, but I have maintained it so it looks brand new. I hate throwing away a piece of equipment that has been well maintained, looks like new, because of one lousy "plug in" part, BUT in this day and age of disposables what are you going to do. Especially when you go to auction sites where you can buy one for half the part price. Maybe I'll buy one of those and keep the other for parts.
  • iowacc Dec 21, 2008
    My heater is BRAND NEW. This is my 2nd heater. I returned the 1st one after only 3 weeks, and this one I have had for 4 days. All it does now is light, fire, blow for 20 seconds then flame out with a huge blast of blue smoke and then shuts off. Same issues. There is only ONE constant. Each time they wont stay on it is BELOW ZERO. It will run fine at 20 or so, but at -4? No. It will not run until the temperature is warmer. I need it only when it IS cold, a heater that will not work when it is cold is worthless.
  • 232 Answers
Silvercliff- since you use the word “plug” I am assuming that you have a spark plug type heater, not the new technology HSI type (hot surface ignitor) that uses a glowbar and an onboard computer.
Reddy heaters are simple to troubleshoot, but you must understand how the system operates.
Since you state that the heater produces a fog at startup indicates that you are getting “some” fuel.
Obviously, the fuel is not igniting.
Now, you must determine if there is any spark. Is a good spark arcing across the electrodes on the plug? If not, is spark being produced by the Ignition Control unit (aka spark box, transformer) ? If not, is the Safety control (reset) sending electricity to the Ignition Control unit?
If there is a good strong spark at the plug, then you are having a fuel delivery problem, even though there is “some fuel”. Understand that the amount of fuel being delivered to the nozzle is DIRECTLY related to the air pump pressure. If the air pump pressure is not correct, then the fuel delivery is not correct. Setting the pump pressure is not difficult. Pump pressure is CRITICAL. Instructions for setting the air pump pressure can be found at .
If the air pump pressure is correct, then check the following:
  1. Cracked air line preventing correct pressure at the nozzle.
  2. Cracked nozzle adapter preventing the fuel from being SUCKED from the tank.
  3. Clogged fuel filter.
  4. Restricted or worn nozzle. The fact that your heater is a spark plug type heater indicates that it has some age on it. DESA recommends annual replacement of the nozzle. Are you using the original nozzle? Worn nozzles produce a SPRAY. New nozzles produce a FOG. The nozzle produces a cone shaped fog. If the cone is missing (not hitting) the spark, for some reason, then there will be no ignition.
  5. Finally, and don’t laugh, is your fuel 100% kerosene or diesel? Water sinks to the bottom of the tank. The heater draws fuel from the bottom. If there is an inch of water on the bottom…….., well, water will not ignite.
I hope this helps.
Posted on Sep 07, 2008
I think your right SFHBADG, except going into the garage to get away from "Old What's Her Name" ain't that bad an idea.
Posted on Nov 19, 2008
After having the same problem, I have concluded your best option would be to junk the entire thing. By the time you buy parts, you could buy a brand new heater without having the BS involved with a complete rip down and a nagging wife because your spending so much time in the garage.
2 Suggested Answers
  • 3182 Answers
SOURCE: ready heater 55. all filters
is there a tube to the pressure switch you can clean this could be blocked
Posted on Dec 12, 2010
I have a Reddy heater 30-55,000 btu.. When lighting it I press in the initer for the recomended time but after I release it the flame goes out.. Can you tell me why?.
It seems as if you are not holding the igniter long enough after it fires, have you tried holding the igniter down for a few seconds more to allow the safety cut out to warm up, (Similar to the gas heaters, when ignited keep the flame going for the thermal coupling to heat up), If you do this and it still goes out the safety valve is faulty, but try holding it in longer before messing about with the coupling.
Jan 05, 2012 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater kerosene 110,000 btu . plup it in, fan runs, blows smoke out the front, leaks kerosene also from front, i have cleaned photo cell, replaced plug, cleaned filter and checked lines for cracks,...
Just because there is fuel & spark does not necessarily mean there will be combustion. The fuel must be delivered at the correct pressure, the correct volume, and must be delivered as a fog- not a mist.
My suggestions:
  1. set the pump pressure
  2. be sure the fuel filter is clean
  3. be sure no air leaks or vacuum leaks
  4. Desa recommended annual replacement of the nozzle. They wear out. When was the last time yours was changed?
More troubleshooting tips
Oct 20, 2011 | Reddy Heater-30-55,000 BTU Variable
What makes the heater start up then cuts off after about 5 seconds with a little of kersone running out of the front of it
This is normal. It has a time limit to fire off. The heater will cut off if it does not light.It sounds like it is never lighting up. Check your ignition source. I am not sure if you have a spark plug type or a glow bar.
Jan 03, 2011 | Reddy Heater-30-55,000 BTU Variable
Thermo coupler problem? the unit will fire with the button held in, but won;t ever stay going when you let the button go
yeah sounds like it firstly try its connection to valve tighten if necassery if this don't work replace thermocouple and if still playing up its the valve
Nov 22, 2010 | Reddy Heater-30-55,000 BTU Variable
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy heater won't stay on
What is the model number? Could be a number of things, depending on which technology is used on your particular 55,000 btu heater.
Nov 19, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 55,000 BTU will not ignite
Ours did that too one year. Seems to me we changed the spark plug, it had spark but too weak I think.
Jan 31, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
525 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
