I had problem with the ink and thanks to your website I was able to solve this problem for Canon Pixma MP 150. I now have a problem with paper sticking when going through the printer. Nothing obvious is in the printer to stop it printing. The paper starts going through on print, then sticks about 2" through. Despite taking a look at the printer, there is no (and never has) been any paper sticking, and no obvious reason why the paper would stick and not just print. I have deleted the printer from my computer, and reinstalled, but still a problem, it will not print, as paper sticks about 2" through the printer.
Jean
No jams before this problem with my printer. Printer has partially been taken apart by hubby. I will try a clean next, many thanks for your quick reply
JeanNo jams before this problem with my printer. Printer has partially been taken apart by hubby. I will try a clean next, many thanks for your quick reply
Jean
You can't post conmments that contain an email address.
This is definitely a mechanical problem. You might want to at least partially take the printer appart and inspect it very thoroughly if you haven't done so yet. Did you have any paper jams before? Sometimes when you remove a paper jam the sheet rips and you end up with some shreds of paper lodged in the printer mechanism causing more jams. Another possibility might be cracked or bent paper guides, or simply dirty rollers (these you can clean with alcohol).
no both are different Here are the list of cartridges u can use MP210 PG-30 Pigment Black PG-30 Pigment Black Ink Cartridge PG-40 BLACK CL-31 Color FINE Ink Cartridge CL-41 Color MP240 PG-210 Black Cartridge CL-211XL Color Cartridge CL-211 Color Cartridge PG-210 XL Black Cartridge
I think this may work.
Reset Waste Ink 1) Enter SERVICE MODE. By pressing Menu, Copy, Scan,Copy,Copy 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [Set] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Jean
