Question about Car Audio & Video
Need wiring diagnostics for a 93 ford villager to speaker wiring
    Novelist:
  • 100 Answers
A good place to get your wiring color codes is a site called installdr.com. Go there and click quick radio wiring then select make and model and you should get the radio wiring guide. I hope this helps. Good luck.
-Andrew Hawkins
Posted on Aug 29, 2008
I need awireing diagram for a premiun sound (jbl) stereo with cd player for a 93 thunderbird
you should get a wiring harness to save you the trouble, however i just put in a kenwood in a 1997 thunderbird, if you cut the black wiring cover all the speaker wires are wrapped together and the other wires will be 12v constant acc, ground, etc. here is a diagram Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire : Orange/Green
Left Front Speaker Negative Wire : Black/White
Right Front Speaker Positive Wire : White/Green
Right Front Speaker Negative Wire : Black/White
Car Audio Rear Speakers Size: 5x 7 speakers
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire : Pink/Green
Left Rear Speaker Negative Wire : Pink/Blue
Right Rear Speaker Positive Wire : Pink/Blue
Right Rear Speaker Negative Wire : Green/Orange
Feb 03, 2013 | 1993 Ford Thunderbird
Where is fuel pump located of 1994 mercury villager
In the Gas Tank.. it is electric. You will need a book if you are going to do this yourself.. the last time I had to replace a fuel pump was on a 95 Ford Contour.. It cost me $600.. if you know what you are doing go for it.. keep a fire extinguisher handy... remember the fuel system is under pressure.. I currently have a Caravan 93 and it uses the same fuel delivery system.. Jim
Jun 02, 2010 | 1994 Mercury Villager
Original wiring in car for stereo what goes where?
This are the colours 1993 Ford Thunderbird Car Radio Wiring Diagram Car Radio Battery Constant 12v+ Wire: Green/Yellow Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: Orange/Blue Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 5′ x 7′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Orange/Green Left Front Speaker Negative Wire (-): Black/White Right Front Speaker Positive Wire (+): White/Green Right Front Speaker Negative Wire (-): Black/White Car Audio Rear Speakers Size: 5′ x 7′ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Pink/Green Left Rear Speaker Negative Wire (-): Pink/Blue Right Rear Speaker Positive Wire (+): Pink/Blue Right Rear Speaker Negative Wire (-): Green/Orange
Jan 08, 2010 | Car Audio & Video
93 mercury villager check engin light comes on for 2 days then off for a day then back on i dont know where to plug in my scanner
I too have a 93 Villager. Recently the check engine light came on especially on the highway cruising speed and it turned out to be caused by clugged EGR. My mechanic cleaned up the carbon build-up ( not replace EGR) from all those 170K miles and it seems to fix the problem. He charged me $150 for the labor only. Also the gas mileage seems to improved a bit as well.
Oct 27, 2009 | 1993 Mercury Villager
Timing belt settings for a 93 mercury villager 3.0
The left cam should be set @10:00 and the right @ 2:00 the crank @ 5:00
May 06, 2009 | Mercury Villager Cars & Trucks
Door issue
no difference from 93 to 98. you need to move door hinges.
go here for villager/quest help
http://autos.groups.yahoo.com/group/villagerquest/
Apr 18, 2009 | 1993 Mercury Villager
I am trying to put a delco radio in a 93 ford thunderbird but the harness is striped to just wires i need the color coding on them so it will work
the red usually is the power input, black is the ground.
attach a ground wire to a 1.5v battery and tap the + of the battery to any of the stripper, when you hear the tap sound from the speaker,that will tell you what wire to which speaker.
if you have any wire left over, try for power ant.
Apr 17, 2009 | Car Audio & Video
OBD-I
Under the Dash on the Drivers Side Left Torwards the Door. on this Model they are Really close to the Bottom of the Dash.
Jan 20, 2009 | 1993 Mercury Villager
93 mercury villager will not start in cold weather
could be a bad ground wire to the battiery or possitive cable
Nov 11, 2008 | 1993 Mercury Villager
Wiring harness cut 93 tempo radio need wiring colors
a quick and easy solution would be to run your own power leads and just use the speaker ...i would suggest using a multimeter
Aug 31, 2008 | 1993 Ford Tempo
Car Audio & Video Logo
96 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
