Dell Inspiron 6000 Alps Touchpad not working
Dell Inspiron 6000 Touchpad not working. External USB mouse works. Touchpad stopped working when USB mouse ws connected (I am guessing). When running in Diagnostic mode, I was able to use the touchpad. diagnostic test did not return anything. I have tried the latest driver from Dell's site for Mouse, BIOS. Checked Registry key hkey_local_machine/systemcontrolsetservicekbdclassstart (value was 1). Any thing else I am missing?
  • ahmjt Aug 29, 2008
    Sorry, I forgot to mention - but one of the first (and obvious) thing I tried was uninstalling the touchpad. The machine reinstalled the touchpad, but it was not responding. After that, I loaded the new drivers from the DELL site). I tried the mouse settings to make sure touchpad and touchpad-buttons were enabled. I tried selecting/not-selecting "Disable touchpad when external mouse is present" option. One thing I recall now is - I once had a problem with my DVD/RW drive on the laptop. DVD was not working. CD was working fine. I tried a registry tweak (delete upperfilter/lowerfilter for a specific key with hexadecimal name that I can't remember now). After that DVD started working fine. I do not know if that has anything to do with the touchpad. I have been using the USB mouse for long time, and I have discovered the touchpad not working recently.
    Not sure about BIOS flash, but I have tried downloading latest BIOS from DELL support. The touchpad works fine while running the diagnostic test (fn + Power_switch to start)!! So my guess is the hardware is fine. To make matter worse, I have played withe the registry this evening and now even the USB mouse is not working any more :( I deleted the upper filter key for the alps touchpad. Before doing that I made a backup up of the registry and created a restore point. After the registry change, restoring to previous restore point or registry backup was not successful.
    Genius:
  • 2,028 Answers
Try unistalling the touchpad driver, and reboot. The machine will find the touchpad and reinstall the driver automatically. These have a tenancy to glitch when using an external mouse, and this should clear it up. Let me know.
Posted on Aug 28, 2008
  • Ryan Rogers
    Ryan Rogers Aug 29, 2008
    You might try a bios download from Dell's support site, and check the connection, sometimes a touchpad connection will get a little dirt or corrosion build up or just work itself out a bit. If the bios flash doesn't and the connection is good, then I'm afraid you may need to replace the touchpad.
  • Ryan Rogers
    A bios flash and a system repair will reset the registry. I would try both of these and see where it gets you.
  • 4 Answers
Go to
Control panel,
mouse properties,
Device Select tab,
remove check from
"Disable Touch Pad / Stick when USB pointing device is present".
Posted on Dec 01, 2008
I have this problem, but the computer did not see the alps touch pad,
Posted on Apr 13, 2011
My Dell Vostro 1014 laptop's touch pad does not work!! The buttons work fine but I'm having problems with the pad. The drivers are up to date and the application used to control the touchpad c
If you have a external mouse, or you can borrow, go into device manager to see if the pad is enabled, if okay! try a system restore bringing the computer back in time before this happened, if still no luck the sensor pad maybe defective, the last option a complete recovery of the operational system to factory setting, this will prove if the sensor pad is defective, or wire ribbon might have come loose from the motherboard.
Apr 01, 2012 | Dell Vostro 1014 Laptop Computer
Built in mouse has not worked properly from day 1. Now my external mouse won't work either. I tried a different external moue, but it doesn't work either.
Unplug everything except the power cord, including the following:
Speakers
Printers
Scanners
USB devices
Personal Digital Assistants (PDAs)
USB flash drive or other external storage devices
External Monitor
External Keyboard
External Mouse
If your computer is attached to a docking station, undock it.
Make sure the touchpad or your finger has no dirt, grease, liquids or food on it (the touchpad has to make a good contact with your finger to work correctly).
Turn the computer back on and retest the touchpad.
When the touchpad still does not work correctly proceed to step 5.
When the touchpad does work correctly, attach one external device at a time and test the touchpad to see which one may have caused the issue.
Make sure the latest driver for the touchpad is installed (you may need to use a external USB or Bluetooth mouse), for more information refer to:
"How to Use the Drivers and Downloads Website"
May 26, 2011 | Dell Inspiron 1525 Laptop
My mouse, cursor freezes before I can even enter my windows password to log on.
Try installing an external mouse and see if that works.
If it does, you might want to reinstall the ALPS Touchpad driver for your laptop.
Hope that helps.
Dec 15, 2010 | Dell Inspiron 1420 Notebook
I have a Dell Inspiron 1545, how do i adjust touchapd sensitivity?
control panel, mouse, touchpad tab, the Alps touchpad driver should be configurable there
If not install latest Alps driver
Jun 07, 2010 | Dell Inspiron 1545 Notebook
Inspiron Keyboard Jumps Around
Install the latest touchpad driver from support.dell.com
There is a setting in the touchpad tab of the mouse driver. Either Enable PalmCheck or Disable touchpad when typing (Depends on Synaptics or Alps drive I believe)
With palmcheck enabled, the touchpad is disabled when typing
Jan 24, 2010 | Dell Inspiron 1420 Notebook
I have an Inspiron 6000 Laptop the inbuilt key board is what i use. in paticular programs like Google talk and Google Mail the cursor behaveserratically mostly going backwards and sometimes forwards. How...
Control Panel, Mouse, Touchpad settings. (Depending on the driver Synaptics or Alps), there are settings to disable the touchpad while typing (Enable Palmcheck, etc)
Dec 17, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 8600 Touchpad and Tracking Ball doesn't work
Download the Alps Touchpad driver for the Inspiron 8600 from the FTP site of Dell (http://ftp.us.dell.com/input/R113813.EXE)
Let me know if this helped!
Jan 12, 2009 | Dell Inspiron 8600 Notebook
Computers & Internet Logo
6,850 people viewed this question
David Payne
David Payne
