Question about JVC Car Audio & Video
My jvc kd-dv7302 car headunit has a problem with its usb reader . It cannot read all files/folders on the usb device inserterd. all files are readable on other head units with similar usb readers
hogan doan
  • 227 Answers
SOURCE: JVC KD G 322 cd car reader problem
One of the way to reset it is disconnect the battery and wait for ten second and then reconnect it. Hope it will help.
Posted on Mar 05, 2008
SOURCE: JVC KD-SH1000 unable to get
Will only read SD cards formatted with FAT16 file system, which limits capacity to 2GB.
Posted on May 08, 2008
  • 35 Answers
SOURCE: 5-1/2 inch floppy diskette reader
good luck reading them at all ...
due to the media the data will go away after time specialy if they have been packed in boxes against one another.
that is just fact.
but you can find drives at flea markets ebay an df computer shows.
Posted on Jun 13, 2008
SOURCE: jvc kd-g441 usb car stereo unit
Here's what Halford's told me to do; Remove the unit (by taking off the front bit, then using the keys to get the main bit out). You should see a red and a yellow power cable. Take the red and yellow cables out of the sockets, and swap them. This apparently re-orients the power and allows the unit to store data and resume playback etc more effectively. Hope it helps...
Posted on Feb 10, 2009
  • 52 Answers
SOURCE: JVC KD-AVX 40 compatiable USB H/Drive
You can use any non powered USB drive (gains its power from usb only). You just have to plug it into your PC and select Properties > Format then make sure you format it in FAT12, 16 or most commonly (recommended) FAT32 file system.
Once you've done this you can transfer all your music onto it then plug it into the USB port lead from the back of the head unit
Posted on Jul 02, 2009
Some albums in USB stick are not recognized by JVC X40 USB reader
hi mark, before going further try this out.......use a smaller usb stick like a 4gb or 8gb with some music mp3 data arranged in folders like the way you have, and check out the response/performance. from my experience many car units cannot run/decode info from large capacity usb drives. if this also does not work then check out your nearest jvc service centre for advice. cheers.
Feb 24, 2013 | JVC Kd-x40 1 Din Digital In-dash Car...
JVC radio operation instructions for model kd-S34
JVC has the manuals on their support site: http://books.jvc.com/booklist.asp?Model=KD-S34 . The direct link to the installation guide is: http://books.jvc.com/Download/138327414/GET0518-002A.pdf . The operating instructions are here: http://books.jvc.com/Download/138327414/GET0518-001A.pdf . If you want to buy a printed copy, see http://store.jvc.com/product.asp?Model=KD-S34 . Note you will need a program like Adobe Reader to read the files.
I hope this helps.
Oct 03, 2011 | Car Audio & Video
I have a JVC KD-AHD79 stereo. I tried plugging my Samsung Fascinate phone into the USB port to use the music on the memory card but it either says "cannot play" or gets stuck on...
This unit is able to take I Pod and I Phone. If unable to connect your particular phone/device via bluetooth please note the following?
• Make sure all important data has been backed up. • You cannot connect a computer or portable HDD to the USB input terminal of the unit. • Avoid using the USB device if it might hinder your safety driving. • Electrostatic shock at connecting a USB device may cause abnormal playback of the device. In this case, disconnect the USB device then reset this unit and the USB device. • Do not leave a USB device in the car, expose to direct sunlight, or high temperature to avoid deformation or cause damages to the device. • This unit may not play back files in a USB device properly when using a USB extension cord. • USB devices equipped with special functions such as data security functions cannot be used with the unit. • When connecting a USB cable, use the USB 2.0 cable. • Do not use a USB device with 2 or more partitions. • Depending on the shape of the USB devices and connection ports, some USB devices may not be attached properly or the connection might be loose. • This unit cannot recognize a USB device whose rating is other than 5 V and exceeds 500 mA. • Do not pull out and attach the USB device repeatedly while "READING" is shown on the display. • This unit may not recognize a memory card inserted into the USB card reader. • Connect only one USB device to the unit at a time. Do not use a USB hub. • Operation and power supply may not work as intended for some USB devices. • The maximum number of characters for: - Folder names : 63 characters - File names : 63 characters - MP3 Tag : 60 characters - WMA Tag : 60 characters • This unit can recognize a total of 65 025 files, 255 folders (255 files per folder including folder without unsupported files), and of 8 hierarchies.
Good luck with it.
Mar 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
I can't play my certain playlist on my iPod through my receiver
When Connecting Smart Items like Apple Stuff to JVC the DEVICE provides the JVC with the music. You cannot drive the Apple Device through JVC remote or front Buttons.
Jan 24, 2010 | JVC Car Audio & Video
Need to change clock on JVC kd-pdr30
http://resources.jvc.com/Resources/00/00/91/GET0467-001A.pdf
This link is the user manual for your Radio. Colck instructions are found on page 6. This File is a PDF Free adobe reader will open it. Here is the link to adobe reader just in case you need it.
http://get.adobe.com/reader/
Every thing is free.
Hope this helps.
Please leave feedback
Nov 16, 2009 | JVC KD-PDR30 Car CD/ MP3 Player
Remote wire?
The remote wire on the jvc unit is blue/white stripe if that isn't there it's the blue wire
Apr 08, 2009 | JVC KW-AVX800 CD Player
HDD with videofiles not working
I had the same problem on memory stick. If I have pictures only on memory stick it is working (pictures played in a slide show). After that I've try with a mixed CD (MP3 + pictures) and was the same problem - only MP3 played. I think KD AVX33 doesn't know to read both type of files at the same time.
Feb 26, 2008 | JVC KD-AVX33 Car Video Player
My jvc kd-g820 is not redinf files from my usb drive
Hey make sure there capable with your deck i have this deck and downloaded the manual and lernt i cant use a 8g usb stick and it reads most mp3s
Jul 26, 2007 | JVC KD-G820 CD Player
Car Audio & Video Logo
161 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
