Question about HP LaserJet 8150n Printer
HP 8150 gear noise
When printing, gear noise is very loud.. tried lubind and removing main gear assy, no luck, any Ideas??
  • rnrfisherman Aug 28, 2008
    I attempted to take it apart and haverun into a dead end.... how does one replace this gear assy?? seems like it has too much "slop" in the gears...is there a tension spring that may be missing??
  • 446 Answers
Chances are there is a defective drive gear inside you need a tech to resolve this prob.
see if the gear tooth are smaller than before, if there is any sign of powderized palstic all around then gears need to be changed no amount of lubrication can corrrect this.
also check the orientation of gears, for any sign of mechanical binding this can also cause grinding and unusual sound
cheers
Posted on Aug 28, 2008
What the part no for main motor assy. The whole assy that needs to be replaced due to unusual grinding noise during paper run.
You cannot typically buy the entire assembly as one piece. You need to purchase the main motor and then all the related gears. There are companies out there that sell a kit with all the gears, look for one for the 5200 laserjet as they are the same.
Aug 31, 2016 | HP LaserJet M5025 MFP Printer
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Drum motor noise
Need to open the entire printer, don't feelbad if you are capable you start to open other pl don't open it,its major issue..While printing main motor driving entire printer except fuser assm, entire printer load on Main motor assembly, in main motor assembly contains motor and gears, pl see the marked gear in snap I experienced this gear found warn out, this is suits hplj 5200 main motor gear, you can choose this gear and its easily available.. replace this gear, but opening the printer is difficulty.. thanks..
Feb 04, 2012 | HP® LaserJet M5035 MFP Laser...
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
Banging noise when printing. Changed cartridge and didn't help.
That is a swing gear and its damaged. Service will be needed. The part is an RM1-0043 Swing Plate Assy and you may also need to replace the fuser RM1-1082. The cost plus repairs will be around $250-$300 due to the 45 minutes it will take the service tech to remove the swing gear assy.
Jun 24, 2010 | HP LaserJet 4250n Printer
When i print, the printer makes a grinding noise the paper gets jamed also.
Remove the fuser unit and check if there is a residue on the side of the gears. If so, you 'll have to replace the swing gear assy. Partnumber 5851-2766. It is not an easy job!!!
Gerrit Jan
Oct 28, 2009 | HP 4250 Monochrome LaserJet Printer
Color Laserjet 2550 Loud Noise when starting up and printing
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
May 29, 2009 | HP Color LaserJet 2550n printer + HP Color...
Loud noise
If your also encounter prints that have a roller/crease at the right and slight crinkling at the left then your fuser should be replaced.
Nov 19, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet 8150n Printer Logo
551 people viewed this question
Seeker5211
Seeker5211
