Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Candy Futura Fridge Freezer
Product is about 2 Years Old... for the last 8 months or so, the hole at the back of the fridge for excess water to go down keeps overflowing and spills into the bottom of the Fridge. Having to stick paper towel every two days to "soak" water up.
Have defrosted freezer compartments in lower half, this seemed to help for a few days but now its back to its usual overflowing tricks, somebody please help!!!!
    President:
  • 1,462 Answers
Very simple fault - drain hole is blocked. push something flexible down the hole till it clears and water flows away freely
Posted on Aug 28, 2008
  • peekairns
    peekairns Mar 22, 2012
    My brand new candy fridge freezer is leaking water underneath - engineer is coming out for the second time on Mon. Drain hole is in a covered unit so can't be blocked (only 3 weeks old) Anyone else had this problem? Les
Have fridge freezer 8 years old , lights work but warm inside and all food defrosted , is it worth getting fixed or shall I get knew one?
My advice would be to go for a new one as the product you are holding is more than 8 years old. Although, obviously new is going to be a little on the expensive side as compared to getting this one fixed but technology has moved a long way in the last 8 years. Thus, your current Freezer is going to consume more electricity and even after being repaired, the performance shall not be optimal. While, the new Refrigerator not only is going to be Lessen your electricity bill but shall be a better choice both in terms of Style, Structure, Optimization and Performance.
Oct 30, 2012 | Refrigerators
Amana BRF 20. I know there is a problem when the fridge part is getting warm. The first time, we called a technician and he told us that we had ice build up in the bottom freezer part, at the back of the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Defrost timer/control board is bad...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 14, 2010 | Refrigerators
I have a Candy Futura Fridge Freezer and the fridge keeps getting a build up of water. The freezer seems ok
heatman101
Aug 24, 2010 | Candy CPCA240FFK Bottom Freezer...
Candy futura cfmf 266a fridge freezer problem
Either the thermostat is set to high or you need to replace the thermostat.adjust it to 1/2 way position position and if temp is to cold and it doesnt want to switch off, it means the thermostat is faulty.
May 21, 2010 | Candy CPCA240FFK Bottom Freezer...
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Liebherr f/f, drain gully is retaining water, drain hole is clean
the fridge probably isn't quite level - or tilt the side that is holding the water slightly so it down to the drain hole - 1/8" could make the difference
May 05, 2009 | Liebherr KES3660 Stainless Steel...
Water under veg bins
Hi. thanks for the question . the problem you have is with the drain tube, from under the freezer wall ,in the fridge. that tube is clogged up . pull fridge away from wall. locate the drain hose at the drain tray. clean. also clean all coils behind fridge thanks the appliance doc
Sep 30, 2008 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
Candy fridge freezer
i have candy fridge freezer which the thermostat is on high setting but not cold as it should be. There is build up of ice around thermostat at the back of fridge inside. What is needed to repair?. Any ideas? Cheers!
Nov 02, 2007 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
372 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
