Question about Linksys Wireless-G WRT54G Router
Then what? after i log in to the website with that password how do i change NAT
  • 148 Answers
See page 69, 72 and 77 of the manual
Posted on Aug 28, 2008
  • Pamela Bates
    Pamela Bates Aug 29, 2008
    You must want to change the NAT for some reason. You haven't mentioned why. Those three pages have the methods for changing NAT for a few possible reasons. Follow the instructions for what it is you are trying to do.
How can I changes my NAT-type from NAT-type strict to NAT-type 2 on Playstation 3? My router is a Gigabyte GN-BR01G
By default the IP address should be set to 192.168.1.254, insert this in the browser. You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are admin. Click the Ok button to log in to your router.
Click the Virtual Server link near the left of the page.You should now see a new menu. In this new menu, click PPPoE/DHCP/Static.
PSN requires you to forward the following ports:TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658 Go ahead and enter the settings shown above into thePPPoE/DHCP/Static Configuration menu.enry.png When you're finished, click Submit near the bottom of the screen to save your changes.
And that's it! You're done!
Jul 27, 2011 | Computers & Internet
NAT IS STRICT
STEPS TO CHANGE NAT SETTINGS TO "OPEN":
1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
I do not know how to change my NAT setting to open on Xbox Live
First of all I would just like to cover the basics of strict and moderate NAT settings. For those interested, NAT stands for Network Address Translation and is used to prevent problems with information being sent over a shared network.
With the XBOX 360, Microsoft have defined three categories of NAT. These are:
1. Strict
2. Moderate
3. Open
You can see the NAT level for your XBOX Live connection by going into your
1. System blade
2. Network Settings
3. Test Xbox Live Connection
For you question on how to open your NAT setting follow the steps below:
1. Type the IP address of your router in a web browser.
2. It will prompt you for a user name and password once connected
3. After logging in you will have a control panel of setting up different settings in your router.
4. The IP address, and default user name/password are different on every route
Note: 192.168.1.1 is a pretty common address for most routers.
5. Check the manual that came with your router for that info.
I also provided a few links below of password lists of different routers.
Click Here
Click Here
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
How do I change my NAT settings on this modem
Your NAT settings have to do with your router, not the modem. Log into your router's control panel. This is normally done by typing 192.168.1.1. If that doesn't work, go to Start, type in cmd, hit Enter, then type in IPCONFIG. The Gateway Address is what you want to type into your Internet Browser. You will need to log into the router's Control Panel once you type this in. This is usually done by typing in "admin" as the username, or the password, or both.
This will be different depending on the manufacturer of your router, but once you log in, look for two advanced settings called NAT and UPNP. They should be near each other. You want to change NAT to Open.
If that doesn't work, go to http://www.portforward.com and check the port codes from the service you are trying to connect to. You can enter these codes into the Port Forwarding section of your router's control panel.
Hope this helps!
Feb 14, 2011 | Arris SURFboard® SB5101 Cable Modem
I am trying to log into my router to change the NAT type, So i reset the router as the default username and password. Now when I click on the router in the start menu, it switched the router off? I am...
You do not need the software that comes with any modem:
Reset the router:
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the reset button on the rear panel of the router.
1. Press and hold the reset button until the Power LED turns red (about 6 seconds).
2. Release the reset button and wait for the router to reboot.
To log in to the modem router:
1. Type http://routerlogin.net or http://192.168.0.1 in the address field of an Internet browser.
Enter admin for the user name and password for the password, both in lower case letters.
NAT automatically assigns private IP addresses (10.1.1.x) to
LAN-connected devices.
? Enable. Usually NAT is enabled.
? Disable. This disables NAT, but leaves the firewall active.
Disable NAT only if you are sure that you do not require it.
When NAT is disabled, only standard routing is performed
by this router. Classical routing lets you directly manage the
IP addresses that the DG834G v4 uses. Classical routing
should be selected only by experienced users*
? Disable Firewall. This disables the firewall in addition to
disabling NAT. With the firewall disabled, the protections
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 28, 2010 | NetGear DG834G Router
How do you change your nat type to open
In order to open your NAT open u need to get access to your router,.you can do this by logging on your computer and typing in your computer IP Address to the web browser.This should opne up a window that requires user name and password.
user-name should be.. Admin
password. should be Password for most computer rooters.
after that you should be inside the rooter.
click setup.....then advance setup........then begin setup and you should see NAT on the left side.. turn it on.... click next and add your ps3 ip adress then save an restart
i tried to explain to you step by step hope you find this useful
NOTE.... you can find you computer IP Address by typing IP Address on google .
Dec 22, 2010 | Sony Playstation 3 (PS3) Console
How to change your NAT type to NAT type 1
When your console talks about a NAT problem it isnt referring to itself but rather to your router, Log in to your routers web management console, normally works by typing 192.168.1.1 and then entering admin for username as well as password when the login dialog comes up, oor leave the username blank and enter admin for password, from there go to WAN configuration and look for NAT Type or check under advanced routing, just change it from whatever setting its on to the alternate and save your configuration, VOILA... Hpe this helps
Oct 27, 2010 | Sony Playstation 3 (PS3) Console
My NAT setting is strict. ive tried everything i know to change it but cant. i have a silver motorola modem wit a black and blue linksys router but i cant figure out how to change the Nat setting. Im...
Microsoft has a support page to help you with your NAT settings. The prescribed solution is to "open" the following ports on your router:
  • UDP 88
  • UDP 3074
  • TCP 3074
1- Using your Browser, Log on to your router (by normally typing in the192.168.1.1 address check your router's manual to see what the defaultgateway address)
2- If you already know how to log in to your router, then skip thisstep. If you have never logged on to your router then more than likelyyou still have the default initial log in credentials (username: admin- Password:1234 ..... Again check your router's manual to be sure). Theminute you log in you need to change that password immediately, mostnetwork-savvy folks know that 90% of the people out there never resettheir router's initial password and they can log on and make anychanges to suit their needs, including locking you out of your ownrouter.
3- Once you are logged in click on sercruity, scroll tot he bottom and make sure "Filter Internet NAT Redirection" is set to "disabled" ,
4. now click on advanced routing
make sure
Nat is enabled.
5. now click on applications and gaming.
4- Let's start with the NAT setting changes, and we will edit theUpnp settings at the end.
6- You will need to find out what the static/dynamic (preferablyStatic) IP address you xbox360 has. To do so, go to the Dashboard, goto the Console settings page, and click on the network settings to seethe IP address (should be something like 192.168.1.x). You will needthat IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT PortForwarding table (From - To - IP address:)
8 - In the first line enter 88 under both "From" and To" fields, thenenter the IP address of the xbox in the field where you are to enter anIP address. (this is for UDP port)
10- If these changes do not help open your NAT settings, then try theUpnp option. Click on your Upnp Advances settings enter the same information with the ip, and make sure UDP are enabled and checked for. use the port #s for your info as well in the chart. you can name them what ever u want under the application column.
  • UDP 88
  • UDP 3074
thend o the same for
TCP 3074
just make sure the tcp is checked and not udp.
if that doesnt work we can do a full reset on your router.
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, securitykeys, opened ports and services, etc., that you modified. (The defaultusername is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks.This takes about 10 seconds. (To avoid accidental resets, the smallbutton is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password.If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
please rate me, and mark this fixya if it has helped.
Nov 28, 2009 | Motorola Computers & Internet
Xbox restrict chat . csomeone told me a NAt setting needs to be changed. I have a netopia 3347 router help children are screaming
Before You Start
Browse into the Netopia's web interface at http://192.168.1.254 (if using the default IP setting). If your network has a different IP addressing scheme, modify this accordingly.
Login with the admin user name and password. Admin login is required to save changes. If you are unsure of this, contact your network administrator.
Once logged in, click on the Expert Mode link in the left-hand side menu (if that link is visible). In the Expert Mode Confirmation screen click on Ok to continue. This menu bar will be visible at the top of your screen if you are in Expert Mode.
Remember to click the Submit button to save any entries. Hitting the back button without clicking Submit will undo any changes.
Once you have completed your configuration, click on the 3000save.gif symbol in your upper right hand corner to validate the changes. Then click on Save and Restart.
3000home.gif The Netopia Web GUI Home Page in Expert Mode (Firmware v6.3 and later)
Configuration for NAT Default Host
  1. Click on Configure in the upper Menu bar.
  2. Click on Advanced.
  3. Under the NAT heading, click on the Default Server link to Set up NAT default server options. 3546defsrvr.gif 3546dfsrvrmenu.gif
  4. "Check" Enable Default Server.
  5. When the Default Server box appears, enter the NAT Server IP Address for the specified internal host to which NAT traffic should be directed.
  6. Click on Submit.
  7. Click on the 3000save.gif in the upper right hand corner. This will validate that the settings are legal for your network.
  8. If you get Validation Passed, click Save and Restart in the menu. If it doesn't validate the change, a message will indicate the reason. It must be corrected before the configuration change can be applied.
  9. This completes the configuration of the Netopia for NAT Default Host.
  10. the nat server ip is the one you type into the browser were you had to type in your admin log in
Jul 30, 2009 | Computers & Internet
Ps3 nat type 3
In order to achieve NAT 2, you are going to have to set your PS3 to a static IP address and forward ports on your router.
detailed instructions on how to do this and configure your ps3 can be found here:
http://www.pregamelobby.com/forum/sony-reviews-tips/5618-how-get-type-2-open-nat-your-ps3.html
In order to get into your router settings, go to 192.168.0.1 OR www.routerlogin.net (the router sets up its own DNS) and putting in your username and password. If you have not set up a password, the default username and password for this router is "admin"/"password". Follow the instructions in the page I posted once you are logged into the router's webmin.
Hope this helps!
Jul 15, 2008 | NetGear WGR614 Wireless Router
Linksys Wireless-G WRT54G Router Logo
24 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
