Question about Toshiba e800 Pocket PC
E800 spontaneously resets
My Pocket PC E800 hard resets spontaneously, sometimes. I don't see any evident cause. After resetting, there are only the standard progem loaded, nonetheless it keeps doing this, so I doubt it is a software problem. Any suggestion?
    Master:
  • 903 Answers
This hard reset is based on a slack joint. You could test it, if you turn your PocketPC on, and tip on the cover, near the Display or the Battery. If the PDA make a reset, your Pocket PC need a repair.
Posted on Sep 08, 2005
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Oct 16, 2008 | Computers & Internet
Power-on delay
some software program is causeing it to slow down.
try uninstalling some of your programs, or preform a hard reset witch returns the pda into the original state.
How Do I Perform a Hard Reset?
Perform a soft reset when:
  1. Press and hold the Calendar and iTask buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
  3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
    CAUTION: If you push and hold the Reset button for more than two seconds, the battery disconnects. To restart the unit, either plug the unit into the AC Adapter or press the Reset button again.
Mar 23, 2008 | HP iPAQ HX2400 Pocket PC
Problem serial connection e400 using cradle
I am not 100% sure if I am correct in this, but I am quite sure that the e400 does not support a serial connection. Only the e800 does.
Sep 11, 2005 | Toshiba e400 Pocket PC
Toshiba e800 perform hard reset after changing battery
At first you should assure that the backup battery is definitely charged. I suggest to charge the PDA a hole day without using.
Sep 08, 2005 | Toshiba e800 Pocket PC
Reset button
On the right side, on approx 1/3 of the heigth.
INTERNET EXPLORER
I have the same PDA but unfortunately I am not the expert. In my opinion it is not possible to install IE separately. It is not known to me that there is any possibility to download IE for PDA as an individual program. If you have already removed all programs why don’t reinstall the OS and it should work properly again. Did you already install Windows Mobile 2003 SE? Please go to www.microsoft.com and download iExplorer! Try to install it!
Screen Lock up
If I understand you right there is problem with Touch screen because, I suppose, a mylar is not attached correctly to the Top Case Assy. This causes a permanent pressure on the screen. I am not sure but there should be changed the top case mylar. In my opinion you should contact Service Partner in your country and ask them what the best way to solve this problem is.
Hard reset after changing battery e800
Like you know if the PDA is without power supply more than 72 hours there is risk of losing data. In my opinion you should be careful about that and data saving is very important. Till now I had no experience with changing battery and I can not give you a precise advice about that.
Compact Flash card compatiblity
I don’t know why you PDA can not read your card but I found some infrmations about parts which are compatible with e800. As far as I know this types are compatible with e800. Compact Flash Memory Card 1GB (PX1076E-1NME) Compact Flash Memory Card 512MB (PX1075E-1NME)-Type I Compact Flash Memory Card 256MB (PX1074E-1NME)-Type I
HX2410 won't start , have to reset every morning
To my experience, tehre's some evidence this occurs when th device is sort of locked up for too many alarms/notifications being prompted while the device is shut off. This may cause a shortage of memory, for which soft resetting is the only way out. Anyway, as long as you don't drain your battery out, it should NOT cause a hard reset (which would imply losing data and third-party software). Bye
Sep 08, 2005 | HP iPAQ hx2410 Pocket PC
Toshiba e800 Pocket PC Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
