Question about Panasonic Televison & Video
Lamp required for Panasonic projector model PTAE 700E Number on dead lamp HS120AR10-4D. Have you a price and where can I get one from please? I live inPreston Lancs, UK
  • 2,326 Answers
Click here to find the lamp you need. These guys are in the UK.
Good Luck.
Posted on Aug 28, 2008
How to reset the lamp time in Panasonic projector model vex 500
  1. Press the Power button so that a picture is projected onto the screen
  2. Press the Menu button to display the "Main Menu", and then press the F or G button to select "Option"
  3. Press the Enter button to display the "Option" menu, and then press the 5 or 6 button to select "Lamp Runtime"
  4. Press and hold the Enter button for approximately 3 seconds
  5. The "Lamp Runtime" will change to "Time Reset [Power Off]"
  6. Turn off the power and disconnect the power cord
Get A Quote for a Panasonic Projector Lamp or to Replace your Existing Projector Lamp now.
Here are some links that will help you.
Change the Panasonic PT AR100U projector lamp in 3 easy steps DLP Lamp...
How to Reset Panasonic Projector Lamp Timer Projector Lamp Services
May 29, 2016 | Panasonic Office Equipment & Supplies
How to rest alamp hour on panasonic tv with a universl remote model pt 432-c14
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Panasonic ET-LAM1 Projector Lamp for...
Problem panasonic pt 61lc27
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
have a nice day!
Apr 14, 2014 | Panasonic Office Equipment & Supplies
Projector lamp solid red after replacement
have a nice day!
Feb 04, 2014 | Panasonic Lamp For Panasonic PTAE900E...
I have the model TLP WX 2200 and doesn't turn on and after a few minutes, the ON led is green, is blindnig and a bip is heard. After a while, the two of three leds ( on and lamp ) are getting red. What...
It seems lamp is dead/ broken in projector, please check lamp and replace it to fix the problem.
There is lamp cover at bottom side of projector, remove lamp cover to take out lamp.
Detailed procedure of lamp replacement is written in user manual page-45
Click Toshiba Support link to download user manual free copy, if required.
Thanks.
Nov 10, 2010 | Toshiba TLP-WX100U LCD MOBILE PROJ WXGA...
Where can i buy lamp for sanyo lp-z5 projector
You can purchase at www.Nextag.com (just verify the part number first) Sanyo Genuine Original 610-323-5998 Projector Lamp Video Accessories: Projector Lamps, Projector Stands - General Audio & Video Accessories: Carts / Stands Part #: POA-LMP94 more ..., POALMP94 Sellers Found: 6 Available Since: May 26, 2008
Lowest Price: $185.00
Average Rating: star-gray-1.pngstar-gray-1.pngstar-gray-1.pngstar-gray-1.pngstar-gray-1.png Your Rating: ', Cancel:'cancel',AR:'Average Rating:'}); //--> (0 user ratings) No Reviews ' Write a Review Description 145W UHP - 2000 Hour Standard, 3000 Hour ECO Specifications Video Accessories Projector Lamps, Projector Stands General Audio & Video Accessories Carts / Stands Lamp Life 3000 Hour ECO, 2000 Hour Standard, 3000 Hour, 2000 Hour Manufacturer Part Number POA-LMP94 Brand Name SANYO Lamp Power 145 W Compatible Devices LCD Product Type 145 W UHP Projector Lamp, Projector Lamp UPC : 610074006343
Oct 08, 2010 | Eiki Sanyo Projector Lamp
PT-AE700E projector appears to have gone kaput - not lighting up.
Because of high voltages and heat, there are many safety circuits inside these units. If you have a spare lamp, try replacing the lamp. Initial checks are made before the lamp is fired and sometimes a defective lamp can cause this. Also, can you descruibe what you mean by "noisier than usual"? Is the fan making more noise? Something elase making a noise?
Thanks,
Dan
Oct 15, 2009 | Panasonic PT-AE700U Multimedia Projector
Panasonic PTAE 900U with new lamp and counter reset shut off
Reseat the lamp.  I had a similar problem.  Replaced the lamp and everything worked for about 3 hours.  Then, turned the projector off.  Next morning, when I turned it on, nothing.  Stanby/On light flashed green for a minute then the lamp light came on and the projector went into standby.
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
Ptae 900 projector lamp time flashing red at 1800 hours.
It looks like the lamp is getting to the end of its life span. Most lamps on these and many projectors last about 2000 hrs and once they are getting near their end; the timer is setup to warn you about it.
Apr 28, 2008 | Televison & Video
Panasonic PTAE 700U optical block
Are you referring to the bulb? If so it depends on total hours used...a common bulb use is 3000 hrs. That is if it has not had rough usage....which was the case with our projector at The Salvation Army Citadel / church. If the projector is turned off before properly cooling is allowed...the life span of the bulb diminishes quickly......God bless, Capt. Hannu
Dec 29, 2007 | Sony XL-2100U Projector Lamp for...
Televison & Video Logo
324 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
