Question about Pentax *ist DS Digital Camera
DS Front Focus Problem
I was wondering if any one else was having front focusing issues with the DS. I noticed some of my pics did not autofocus where I intended and found that my DS front focuses about 8mm with my FA 50mm 1.7 at close focus (see test sheet). It also does this with the kit lens but is less noticable due the deeper dof. I repeated this test many times and found that the focus line is somewhat out of focus. Can this be adjusted in camera and do you think this is a problem I should try to have rectified?
    Master:
  • 542 Answers
Try focusing on somebody's eyes at a wide open aperture and see where the focus is once you down load it to your computer. Also manual focus the same subject by using the focus screen and not the focus indicator and see if your MF attempts are correctly focused. If you do the focus on somebody's eyes do it at an angle to the face so you have the nose, eyes and ears in the pic, but at an anlge of say 45 degrees so the nose is foremost and the ears rear most, and you will then see where the focus actually is when you down load the pic. When doing the AF, just make sure that you focus on the eyes via the AF indicator and when focuing via MF use the focus screen to get clear focus. Then compare the two. Obviously your subject will need to keep still. This is more of a real world scenario so as you can see how it works with real objects.
Posted on Sep 08, 2005
    Master:
  • 542 Answers
Just be careful about how you do the test as it is very easy to get the incorrect result. The edge of the focus indicator for AF has to be in exactly the correct position or you will get incorrect focus. I would be very cautious about this test as you can very easily get the wrong result. Please try the test again and make absolute sure that everything is set correctly and the focus indication is in the correct spot. It only takes it to be a fraction out to give wildly inaccurate results. Is the camera set exactly to the required 45 degree angle? When I tested my lenses, I folded a piece of A4 paper from one corner over to get a 45 degree angle and used that as a guide for setting the lens angle. It is also an idea to make sure you have the camera close enough to the test paper. Also try setting the camera to MF and then focus the lens to infinity and then switch back to AF and let the camera focus on the test and see how it focuses. Then try the same thing but focus manually to minimum focus and then switch to AF and let the camera AF again and see whether the result is different. If there is a difference then you may have the AF indicator in the incorrect spot. There are so many variables in this test that it is of utmost importance to get the test right. Are you getting OOF shots in your general photography? If not then the test maybe irrelevent and you are possibly chasing demons that aren't there. Only if you are 100% sure you are doing the test correctly and you are positive that it is indeed front focusing that I would then send the camera for repair.
    Master:
  • 542 Answers
I had a similar challenge with my D, the difference being it back focussed, it only happened with one lens, my FA* 24/2.0. Strangely, after returning them both to Pentax, it turned out to be the body, not the lens, which was kind of bizarre! Eventually after 3 months of backwards and forwards with the body, Pentax replaced it with a new one. Everything is now fine (apart from 1 hot pixel, which I can cope with). I pursued the matter with politeness and accepted the delays, the staff at Pentax UK were MOST helpful, but tied by company rules that the repairs had to go back to Germany each time, which added probably 80% to the delays. I ran with film in my MZ-S and digital on my Fuji 602 (backup digicam) while it was being sorted. I must admit I'm considering adding another body, but will probably wait until the year Pentax decide to bring the out D replacement.
Why does autofocus keeps moving in and out on some slides
The autofocus system isn't really "autofocus". It is a measuring system - you manually focus the first slide, which sets the distance from the front of the slide in the gate to the back of the projection lens. By the focus motor moving the projection lens, subsequent slides will maintain that same distance. Continuous focus adjustment suggests that:
1> The curvature of the slide is changing because of the varying heat absorption rate of the transparency.
2> The autofocus system is out of calibration.
3> The autofocus system has a bind (it is being restricted from free operation).
About the only thing a user can do is to make sure ALL slides are oriented the same way in the tray. Beyond that, you will need a service manual and 2 or 3 specialized tools. Parts and tools can be purchased from: www.micro-tools.com
Good Luck !! jim
Jun 24, 2014 | Kodak Carousel 5600 Slide Projector
How do you shut off auto focus on camera?
The focus mode selector switch is on the front of the camera, just below the lens release button. Switch it to the "M" position for manual focus, "AF" for autofocus.
Jun 02, 2012 | Nikon D80 Digital Camera with 18-135mm...
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
Dec 26, 2011 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
My a720 is on auto but won't take a pic everytime just the bright orange light on the front and nothing happens
Soundsl ike you got a autofocus issue and this needs to be taken care of by a camera shop. The issue here is the auto focus sensor the normally causes the camera to not turn on or to turn on and the breif off again. I would have it looked at by a camera shop,
thanks and please do leave positive ratings and feedback for your free answer today.
May 04, 2010 | Canon PowerShot A720 IS Digital Camera
I have an Olumpus d-535 camera that does not Autofocus well.
Try pushing the Shutter halfway down until you get a green "go" indication, and take the pic. This forces the camera to focus, and is something you often have to do with these point and shoot automatic focusing cameras.
Mar 13, 2010 | Cameras
How and When to use AUTO FOCUS and MANUAL FOCUS of my contax t2 camera?
There are no rules or conventions for this. It is totally up to you to chose which method to use.
Sometimes when taking images in close up where a leaf or stalk may invoke autofocus to lock onto the wrong object to get a clear pic, then select manual so your subject is in focus
Depth Of Field is also associated with focusing, autofocus does not always deal well ith DOF situations. It might be better for you to get a simple book on digital photography to help you understand how to get the best results from your camera
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Contax T2 35mm Point and Shoot Camera
Auto Focus not working for Canon EFS 18-55mm lens
I see this same problem occuring all over the internet on Canon lenses. Autofocus not working any longer. For some stupid reason the lense will lock up and quit autofocus while other lenses will work fine. A light pull on the lense focus ring away from the camera body will give a noticable pop or click which unlocks the jammed lense. Try it if you are having troubles with your autofocus. This is a very common problem and worth giving it a try.
May 30, 2009 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Tamron 28-200 AF Aspherical LD. Does it have manual focus? If yes, where?
There should be a switch just in front of the back of the lens marked "AF" and "M". Set it to M for manual focus, AF for autofocus.
Aug 30, 2008 | Tamron 28-200mm f/3.8-5.6 LD Aspherical IF...
Front focus problem
Hey hubro,
This switch is used to set a focus point to so you can quickly focus to the preset distance. What you have to do is set the switch to the on or on with sound setting then focus to the distance you want to preset and then press the set button. While this switch is set to the on or on with sound setting you just turn the focus preset ring which should be in front of the focusing ring and the camera should focus to the preset distance. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 20, 2008 | Canon Telephoto EF 300mm f/2.8L IS Image...
Beginners question : Autofocus
In the custom settings, you can program the "ok" button of the 4-way controller to disable AF. It's kind of a handy little trick. It's called "Ok button when shooting" or something.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Pentax *ist DS Digital Camera Logo
70 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
