Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Distance of reception
Hello i have two sandwich vans in the peak district on the a57 snake pass but where one of them is situated there is no phone reception on any network as it is sites right in the valley and it ia about 10 miles away from the other one.we need to contact each other as a matter of safety and as there are no two way redios that would work i want to know if there is a cb that would be able to be used under those conditions ,,,,thanks geoff
  • 126 Answers
Oh yeah. The best radio to get reach that distance with no problem would be a 10 meter, such as a General Lee, Connex, Stryker, or Galaxy with a 2 digit model number. Those, with a good antenna set up properly, will reach out 10 miles real clear and up to 14 - 15 miles with some reception loss.
Regular cb radios, such as Cobra, Galaxy 3 digit model numbers, Uniden, etc will have a decent reception, but generally when used barefoot, will only transmit and recieve about 6 miles real clear and up to 9 or 10 miles with a decent amount of signal loss.
Now, you do not have to have a big, expensive antenna to get the distance you want, you can do it with just a cheaper fiberglass stick antenna like a Francis 4 1/2 foot. After I installed a Francis antenna and a General Lee on a tuck outfited the other day, I was able to talk to a man apx 14 miles from my location.
The main thing to look for when installing the antenna is that you have a good coax (braided center conducto and 95% braided sheilding), and that the antenna is not grounded out, just the bracket (this is what makes your ground plane). Make sure the nylon spacer (looks like a plastic washer with a lip on it) is place on top of the antenna mount, with the lip facing down through the hole. You can use a magnet mount antenna, but you will have much much better luck with a hard mounted antenna.
If you have more questions, or if you need me to send a picture showing the placement of the antenna and bracket parts, dont hesitate to email me.
Dean Pitts
Rollin CBs
Posted on Aug 31, 2008
are you using load speaker this some times causes this problem you have,the distance problem maybe signal strength/bad reception
Aug 26, 2015 | Cell Phones
Unlock micromax a57
pc to format
Apr 28, 2013 | Cell Phones
I have a problem I have sim lock sim lock for Siemens A57. And I'm still writing instrument is blocked! Kod network .. AUZ with the advice ... I do not know
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Dec 17, 2012 | Siemens A57
I have lost my instuction manual for the Siemens A57. Need a replacment.
You will be able to download the manual HERE.
Kind regards
Aug 16, 2010 | Cell Phones
Kdl-37w55/57 sony bravia problem is every so often the picture seems to stutter,delay best way to describe it. Any ideas
hello, try tightening your antenna connection this happens when your signal input cable is fualty or loose check that first. then try all other connection that come from your cable,sat reciever or antenna hook up. if your using a digital reception device or digital antenna check those connections to. and be aware that digital reception has interuptions and they depend on the distance between you and the digital signal broadcast station, sometimes storms and atmospheric conditions may cuase a brief lapse in the signal.(stutter) what are you using for a reception? satelite, cable or a digital antenna? hope this helps
Jun 04, 2010 | Sony Televison & Video
Driving a 2003 Ford windstar. Went to pass and
Very common on this make and model trans, pump drive splines inside torque converter strip out and pump is not turning, Most times there is no damage to pump shaft. Remove trans and remove torque converter, inspect the splines at the very bottom of the hub hole. If stripped out inspected pump shaft splines which are the smaller center splines coming out of trans, if ok replace torque converter and re-install trans, change out fluid, clean any metal from magnet and replace filter, fill with fluid and verify proper operation.
Mar 01, 2010 | 2003 Ford Windstar
People can't hear me clearly on my KCA-BT200.
Bluetooth originally had a limitation of about 30 feet +/-, however that doesn't mean great clarity until it reaches its peak distance range. With that said, I would suggest trying to move your phone around in the vehicle to get the shortest distance possible to the receiving Bluetooth device (KCA-BT200).
May 30, 2009 | Kenwood KCA-BT100 Wireless Headset
Can't send a fax.
This can be tricky and sometimes requires some playing around with to get the settings you need. Here is a document that HP created for just your situation. You may need to try it a few times to get the timing right but once you figure it out you should be able to use the same formula for all other fax calls long distance.
Jan 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
131 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
