Question about Epson Stylus DX6050 All-In-One InkJet Printer
Epson Dx6050 not printing in magenta & yellow? Have cleaned heads 5 times now & Im nearly out of ink. Its a brand new printer
Have you tried taking them out and putting them back in? Sometimes they don't 'seat' properly. Are they Epson carts?
Posted on Sep 18, 2008
Epson stylus c88 red ink prints yellow
print a check of the nozzles, and check what colour (magenta) is not working. If the cleaning part does not help, perhaps you should put a new cartridge in, or clean again.
Feb 17, 2015 | Epson Stylus Office Equipment & Supplies
Cant get my Epson Workforce 633 to print. WILL NOT print black.
check if ink came out of the head or nozzles if not then first open the nozzles and head with warm water.
Feb 10, 2015 | Epson WorkForce 633 All-in-One Inkjet...
Replaced T0603 magenta ink with brand new cartridge. Ink levels show its FULL. But when do nozzle print check, no magenta line will print. Trying to pring something with red clip art and can't get the...
Depending on when you last used your printer it may take a few head cleans before the ink prints. Print a nozzle check after each clean (uses minimal ink).
Also be aware each clean depletes your other carts as well.
Jan 09, 2011 | Epson Stylus C88 InkJet Photo Printer
My Epson R230 printer does print Light magenta and yellow ink
1. open a document. 2. control-P - shortcut for print. then click properties, click maintenance, then click head cleaning. after this print check pattern. continue doing this until your light magenta and yellow ink gets clearer. if it didn't work replace your light magenta and yellow cartridge.
Nov 18, 2010 | Epson Stylus Photo R300 InkJet Printer
My CX4900 printer only will print in magenta &
plz check printer alignment & printer ink stuats, is that possible other ink were not active.
Nov 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
No yellow
buy a new one srry man if u eney thing els tell me at alexswierenga@yahoo.com
May 29, 2009 | Epson Stylus Pro 7600S InkJet Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 04, 2009 | Epson Stylus C86 InkJet Printer
Not printing magenta ink and tried cleaning heads already
Hi, one or two head cleans won't clear a clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 28, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus DX6050 All-In-One InkJet Printer Logo
134 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
