When I try to fax a letter, there is constantly a busy type of sound that comes no matter what fax number I try to send to. Any ideas? hp officejet 5510xi all in one
  • ciara1 Sep 04, 2008
    dials the number carries the paper through then displays fax failed error message388
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Hello all I have a hp 4315v all in one printer /fax and i would like to see if the fax is working is there a test number i can use to test it out with
HP has a Fax no. to test.
Send any test page as fax on the 1-888-473-2963 and wait till it is send. Once the fax is sent, you will receive a fax as notification ( confirmation ) of the fax being received by HP.
This above no. sometimes is busy so you may need to give couple of tries till you succeed.
Or the best way is to send fax to any of your friend who owns a fax machine and ask them to send fax back to you.
Regards,
Ron
Mar 07, 2011 | HP OfficeJet 4315V All-in-One Printer
I want to know how i can use my copy machine to a fax so i can use it for incoming or outgoing?
Install software
Make sure all cables plugged: phone cable, USB cable to computer
Send fax from computer:
- print your document to printer HP .... FAX
Send "traditional" fax:
- put your document into scanner input
- type phone number on HP Officejet keyboard
- push button "Send"
If your HP Officejet if connected to phone line, it reseiving faxes automatically.
Hope this helps
Nov 12, 2010 | HP Officejet 4215v All-in-One Printer
HP Officejet 6310 All-In-One InkJet Printer Changed home telephone system and now I can send faxes out but cannot receive?
Hi
Check the following link
CAN SEND but CANNOT Receive
  1. Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code. To modify the fax header, use the following steps:
    1. Press the Setup button () on the product control panel.
    2. Press 4 for Basic Fax Setup, and then press 1 for Fax Header.
    3. Type personal or company information using the keypad, and then press OK.
    4. Type the phone number, including area code, for your HP fax product, and then press OK.
  2. Dial 1-888-HPFaxme and send a fax to the HP Fax Test Service.
Jan 04, 2010 | HP Officejet 6310 All-In-One InkJet...
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
I have a Brother InteliFax 4100e. I'm trying to send a fax to a number that is long distance. First I was getting a communication error when I tried to send it. Now I am getting a Busy/No response message....
Does it work all right for other numbers besides the one you mentioned? Sometimes the problem is at the other end. They might have a noisy phone line. Try sending the fax to another place and check the result.
Dec 01, 2008 | HP Officejet 7210 All-In-One InkJet...
Faxing a word document
hi, i would like to know if you have an HP officejet 6300 fax icon???if you have try to print the document using the fax icon DO NOT used the normal HP officejet series icon.if you did used the fax icon it will display the FAX dialog box,input the necessary information needed.just follow the window..
i believe you can now send the fax..
send me feedback for further troubleshooting....
Aug 04, 2008 | HP Officejet 6310 All-In-One InkJet...
Error 344- Fax Function
Try to connect the phone line from the phone oulet directly to the line one connection of the machine.
May 09, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP Officejet v40 - Can send faxes but can't receive
I think you like to setup it for auto FAX. In any case go to setting menu and set as auto and then set after 5 or 6 rings (or as you wish). You can also do the same if you have the utility software that come along with this Officejet model.
Feb 08, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
41 people viewed this question
jasbo
jasbo
