Question about Brother MFC-8440 All-In-One Laser Printer
Sending and receiving faxes problem
Whenever they send me a fax i only get a few lines at the end of page. Also when I send out it does not come out properly lines ect..
Just got a brand new cartridge still the same
  • 320 Answers
You may have a scanner problem, this should be checked by a locaal brother serice cemter. thanks brother tech
Posted on Jan 14, 2009
I have an HP L7780. We are having an issue receiving faxing. The pages are often only 1/4 complete. There is no reported error. It doesn't happen all the time.
Send a fax on this number
1-888 HP FAX ME (1-888-473-2963)
and see whether you receive a fax from hp or not whenever HP receives a fax from any number it sends back a fax to prove the functionality you can say.
the reason behind reviving the 1/4th fax can be fault at sender's end
Apr 21, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Fax sends certain pages in duplicate
If it only happens with that one vendor, the problem is almost certainly either on their end or somewhere in the interaction between the two fax machines.
The most likely answer is that their fax machine has a problem receiving some pages (either because the line is noisy or for another reason) so it has to reprint them. You could tell your vendor to try turning off error correction on their fax machine and see if that makes a difference.
Hope that helps.
Jul 05, 2010 | HP 920 Plain Paper Fax
The fax machine that is sending you the fax may be also sending a confirmation page that is not needed or compatible with your machine.
I have an older machine that prints a confirmation page after each fax. People on the other end sometimes receive a blank page after each fax that I send them while my machine prints a mostly blank page with only a single line of text at the top with the date and time.
Feb 01, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Intermittently, the confirmation page on the fax says the fax failed (didn't go thru) but it actually did. Why is this? The confirmation page is printing false results, indicating the fax failed to go...
This is because some faxes don't have Error Correction Mode capabilities.
If there's a slight distortion on the line, the receiving machine (without ECM) receives a fax with some minor errors. And even though for a human eye the resulting fax page is perfectly readable, for the machine, that thinks only zeros and ones, there was an error detected in the data, and hence the trasmission failed.
Faxes with ECM when they detect an error, ask the sending fax to re-send the last portion of data, and this way can bring the transmission to a 100% successful end.
So the only thing you can do is ask your recipients to upgrade their fax machines to an ECM-capable model :)
Oct 29, 2009 | Canon Office Equipment & Supplies
I am having trouble faxing documents. Whenever I
Hi, you can check that your phone connection from your 7420 to line works. Listen for a dial tone in a phone connected to your mfc7420. If not, your tel comm module could be at fault.
Jul 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Two vertical lines appear on faxed out pages
HP actually provides a service that lets you test your fax machine:
Testing Your HP Fax Machine
See if this helps. Good luck.
Oct 07, 2008 | HP Officejet 5610 All-In-One InkJet...
Sendidng a fax
I have been sending and receiving faxes for over a year on my Lexmark X6100 printer. Now whenever I try to send a fax it will say it is sending the pages but then waits for a redial. After doing the same thing a second time it will print out "remote fax error"
Aug 11, 2008 | Lexmark X4270 All-In-One InkJet Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Faxing problems
if you put the document in right direction(face up or face down)-your scanner unit may be out of order or unpluged firmly into the main board socket check it and reinsert scanner unit plug again.
Jan 10, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Comm. Error
Try this website:
Jun 25, 2007 | Canon L120 Fax Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
47 people viewed this question
James Cagle
James Cagle
Jim Keysor
