Question about Kenmore Elite 45986 Front Load Washer
F 02 I have a kenmore elite front loader. I have been getting a F02 error code. I cleaned out the drain pump but am still having the same error code appear. Any ideas what the problem is?
  • 5,911 Answers
Although you have cleaned out the drain pump, you still may have a clog in the drain line somewhere, or you have a pump that has failed. A noteable area that gets clogged often with small articles of clothing (such as wash cloths, socks, underwear, etc.), is the drain line that runs from the bottom of the wash tub to the inlet side of the drain pump. If you have checked this, the pump clean out reservoir, and all remaining drain lines after the pump, you more than likely have a defective pump. It doesn't take much to damage them, and just because you can hear it running, does not necessarily mean it is working properly. Often, the impeller blades are damaged, impeller shaft becomes stripped, or pump motor windings are worn. The best solution the manufacturer offers is to replace the drain pump. Searspartdirect.com carries the part. Just type in your complete model number and the drain pump will be located under the "Pump and Motor" heading as item 10 (I believe). The pump is sold as a complete assembly which includes the pump housing and the motor. If you need instructions on how to replace the pump, just click on this link:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
If you still don't believe me and wish to doublecheck your efforts before purchasing any replacement parts, the next link explains the "F02" error and how to attempt to correct it:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
I hope this information is helpful to you. Let me know if you require additional assistance.
Posted on Aug 28, 2008
  • Jeff Rockwell
    Jeff Rockwell Sep 13, 2008
    Has the advice given you a solution to your problem, or do you still require assistance?
What does the trouble code f2 mean for the kenmore elite 4t washing machine?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 22, 2011 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite he 3 front load washer...im getting f error 02. it runs fine until the end of the cycle will not drain or spin.
Kevin
May 22, 2011 | Kenmore Elite 45986 Front Load Washer
F 02 error on kenmore smartwash quietpak 9 front loader washer
F02 - Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains: checking_the_drain_pump_on_a_front_loade
Press PAUSE/CANCEL twice to clear the display:
Check the drain hose and make sure it is not plugged or kinked.
Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects.
If the above does not correct the problem, replace the pump.
Hope this helps (remember to rate and comment this answer).
May 05, 2011 | Washing Machines
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Will not drain. Getting error code F02
yes exactly.you are right.its the pump problem. F/02 error code:-- Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
try this :-- Press PAUSE/CANCEL twice to clear the display.
:Check the drain hose and make sure it is not plugged or kinked.
: Check the electrical connections at the pump and make sure the pump is running.
: Check the drain pump filter for foreign objects.
: If the above does not correct the problem, replace the pump.
you can get required parts from www.repairclinic.com
Nov 27, 2009 | Kenmore Washing Machines
My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
"F/02" Long Drain
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Oct 24, 2009 | Kenmore Elite HE5t Washer
I have a Kenmore Elite HE3 front loader washer. I
"F02" is a Long Drain error. The error code is generated when the drain time exceeds 8 minutes. In most cases this means you need to clean out the trap on the drain pump. The following link explains the error and how you need to remedy the problem. There is a follow-on link included that explains how to access the drain pump and clean it: http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore If the error code reappears after you clean out the drain pump, you may need to replace the pump. If the pump motor or impeller is damaged and it is not pumping at the correct volume, the error code will continue until the pump is replaced.
A replacement pump (if needed) can be purchased at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever part source you like, but I have found these sites to be the most reliable and offer competitive pricing.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Sep 08, 2009 | Washing Machines
It shows 02 and f
I'm assuming this is either a Whirlpool Duet or Kenmore Elite front loader? Since you posted no brand name or model number, its hard to determine, but I do know these error codes are usually for these brand washers.
"F02" is a Long Drain error code, which usually means you have an obstruction in the drain pump, drain lines, or the drain pump has failed. The following link explains:
The "SUD" error can commonly occur with this error due to the detection of air in the drain pump (lack of water flow). If cleaning the drain pump reservoir, and checking all the drain hoses does not correct the problem, you may have a failed drain pump.
Replacement pumps can be purchased on line at searspartsdirect.com, appliancepartspros.com, repairclinic.com or pcappliancerepair.com. All these sites offer competitive pricing so shop all of them for the best price.
If you have any questions about this repair please let me know. I hope this helps you.
Jul 13, 2009 | Washing Machines
Kenmore elite washer drain problem
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite H3 ~ Error Code F 02
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Kenmore Elite 45986 Front Load Washer Logo
78 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
