Question about Hotpoint Dryers
When attempting to start any programme on the hotpoint ultima ctd80t dryer, as soon as I push start, all power in the house trips.
    President:
  • 1,462 Answers
This is possibly due to water in the wrong place and being thrown by the fan onto the element.
take the rear cover off, drain the water (won't be much) and dry area with paper towels.
take out the condensor and clean it while you are about it.
feel round at the back and youb will find a small hole for the condensate to flow away and this hole may be blocked. poke something down it to clear
Posted on Aug 28, 2008
Hotpoint ultima tumble dryer
sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
Dryer tripping RCD
Try disconnecting the heater and thermostats.
They are located behind a removeable cover at the rear of the dryer.
If it still trips, then the problem is likely to be more serious.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
My Ultima CTD80 suddenly stop working mid programme, supply is okay and fuses are good any ideas would be a welcome help thank Martin
if you have no display then the overheat cutout on the heater has tripped. can be reset but check air path (door filter and condensor ) as this usually trips for a reason.. safety first.
Oct 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
As soon as you do a spin program at more than 800 it trips the switches in the main fuse box
Sounds like a motor prob to me, unplug motor and try on spin cycle without motor, if it does not trip, then the motor is faulty..
Please rate my solution.
Thanks.
Oct 05, 2009 | Hotpoint Ultima WD72 Front Load...
Keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT WD71 ERROR E 30
Hello john walker24
Welcome
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Huuum,
Please remember to leave a rating!
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
No heat on tumble dry programme. Display flashed F 13.
You need to replace the heating element for the dryer which is positioned on top of the outer drum. Remove the top cover of the machine and locate the heater.
Nov 01, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Extra WMA66
something is shorting out direct, remove plug from power supply and test each item, element / pump / main motor etc for down to earth, replace the affected item
Sep 30, 2007 | Washing Machines
Dryers Logo
122 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
