Question about Pentax *ist D Digital Camera
Playback problem my the camera is *istDS. with camera on, good batteries, a push of the playback button often does not display any images. The camera does not leave capture mode. Anyone experiencing the same. Ideas welcome. This "problem" will ocur when first turning it on when I think it should go directly to playback when button pushed.
  • 542 Answers
This might sound stupid, but make sure your other fingers are no where near the shutter release. Sometimes I accidentally nudge it when in playback...
Posted on Sep 08, 2005
How to review pictures
Press the PLAYBACK button that is located above the Display at the right side and left to the Zoom buttons.
Once you press the PLAYBACK button, the Camera goes in to the Playback mode. Now you can use left and right arrow buttons to view the images.
To playback the movies it is required to press the center button.
Jul 17, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Help! Won't turn on
Fuji suggests; "If the digital camera will not turn on, run through the "Checklist" given below. If this does not solve the problem, take the camera, the batteries, and the AC Power Adapter to an authorized FUJIFILM service center for testing and repairs. [Checklist] 1. The direction of your battery might be wrong. Confirm it and put it again. 2. Load new or fully charged batteries. 3. The battery terminals may be dirty in a way that cannot be seen (fingerprints, etc.). Wipe the terminals clean with a soft cloth. 4. Press the Power button again firmly." Cleaning the battery contacts sounds worth a try. Fuji also say; "Please use only alkaline batteries or Ni-MH rechargeable batteries with Fujifilm digital cameras Please note that instruction manuals provided with Fujifilm digital cameras recommend that only alkaline batteries or Ni-MH rechargeable batteries are used with those digital cameras which require AA or AAA type batteries. If other types of batteries are used together with an AC adaptor, this may result in the rare occurrence of the battery overheating. Please do not use batteries other than those recommended in our instruction manuals." Check that the type of battery is correct Did you buy the camera new? is it still under warranty? Here is the link to the support page for the s7000 including manuals, repair centre details etc; or direct to the manual; Apart from contacting Fuji for service, the only suggestion I could find in the manual was that the battery cover may not be closing fully. Worth checking. Hope this helps :)
Jul 01, 2007 | Fuji FinePix S7000 Digital Camera
S1IS canon camera
Apparently the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all.
To determine if the CCD (image sensor) is working properly, follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service.
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, products exhibiting the above-mentioned
malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Dec 01, 2009 | Canon PowerShot S1 IS Digital Camera
Nikon D90 Image playback Mode
Hi - My D80 allows the length of time the the image displays to be set using the menu system. You shouldn't have any trouble setting this. Mine can be set from 5 sec to 10 minutes. Lookup Monitor-Off in your manual.
Apr 27, 2009 | Nikon D90 Digital Camera with 18-105mm...
I have a Nikon d70, and I can not get it to display only one image on the LCD screen. I have held down the button on the top right side as directed, but to no avail. Help Jb
Push your playback button once the camera is on.
Then push you your thumbnail button. (this is the second button from your playback)
watch your monitor and keep hitting the thumbnail button until you get to the single picture view.
Dec 07, 2008 | Nikon D70 Digital Camera with 18-50mm Lens
Canon Powershot A70
There is a button on the back that can be pressed called Disp. (stands for Display). There are two or three settings it flips through each time you press the button. Press this button a few times to cycle through the choices in each of the playback and camera mode to see if this resolves your issue. Happy snapping...
Nov 23, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Lens Stuck and No Power
I was just playing around with the camera and I don't know if it decided to work or if I pushed the right combination of buttons, but it worked. I pushed the green playback button, red camera button, and the power button all at the same time and it worked. I have no clue why it worked, but it did. Maybe it will work for someone else!
Oct 18, 2007 | Casio Exilim EX-Z750 Digital Camera
No visual when I turn the camera on
This may seem crazy, but any chance you pushed the display button by accident? This toggles the screen on/off.
Aug 22, 2007 | Canon PowerShot A710 IS Digital Camera
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
IstD LCD Screen...Problem
Resolution on the LCD is rather "rough," but I think all these tiny screens are that way. Considering the "roughness" of the photos in playback, and their sharpness when viewed full on on a computer, the text is about up to as good as this screen can produce. Or, in other words, I'm see'in what your see'in as for text. I think it's just normal.
Sep 08, 2005 | Pentax *ist D Digital Camera
Pentax *ist D Digital Camera Logo
70 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
