Question about HP iPAQ H4150 Pocket PC
4150 battery charging
I cannot charge the battery in the charger. It appears that the computer recongnizes the pda but will not charge-old or new battery thanks
    Master:
  • 450 Answers
When trying to charge the battery, do you get any Amber LED indicator on your iPAQ? It should be flashing when charging and solid when fully charged.
Posted on Sep 08, 2005
SOURCE:
I have a dell axim pda that I hadn't used for awhile. I charged it and saw green light, but when disconnected charger the light went out and still can't turn on. Purchased new battery and sa
LCD cable is loose inside, need to be opened up and reseated or replaced, or replace main board, if under warranty call DELL support to request onsite tech to repair.
Sep 29, 2017 | Dell Axim X30 Pocket PC
Wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 09, 2012 | ZTE Avail Bluetooth Music 3G GPS Android...
I want to charge my battery with a usb cord from the computer but my phone had been discharged for two weeks now and i need help
Then it means you have too boost the battery before it will be able to get charged. First try to insert the battery into another PDA and try to charge it there, it will take a little while to get it to charge, since it has been dead for 2 weeks now. After a little while the battery will begin to charge, or you can get en external/universal charger to charge your battery before inserting it back into your PDA and charge with a computer. That should do the job for you.
Hope this information helped.
Jan 11, 2011 | Computers & Internet
Replaced ipaq 4150 internal backup battery but
read the manual yet, or lost it> or?
most of these have 2 batteries
one that pops out one more that solders down.
guess which one retrains data.
finding parts for relics like this is not fun
what good is this thing besides, wall art?
why ask here at all, we are not HP , nor are there HP books here.
so ask here.
there are folks there that might remember so long ago
or even have old books laying about after all they are HP.
https://h30434.www3.hp.com/
Dec 10, 2017 | HP iPAQ H4150 Pocket PC
Replacement new Battery In PDA not functioning
I will be writing off the PDA as it is now over three years old and updating to more recent technology. I have not yet made my repalcement choice.
Jan 28, 2010 | Palm Tungsten T3 Handheld
Ipaq H3835 PDA - won't hold charge??
If you purchase a new battery, they usually come with directions and special tools to change the battery. I had the same issue with 2 of mine when I got them at a used electronics store. IF it is the battery that is not working, then replacing it is easy, and you can get a replacement at your local Battery-Plus store.
In my case, one was fixed by a new battery, the other was not, and I actually had to press pretty hard in the cradle to get the second one to work. It never worked out of the cradle, so I gave that one to a neighbor kid to tear apart and see if he could get it working. (I got them for $15, so no big loss.)
Apr 21, 2008 | HP iPAQ H3835 Pocket PC
Battery won't charge after being replaced
The charger might be bad. Or then the pdas connector is bad, or the motherboard is damaged.
to find out is your charger working you could use a tester to test it or another pda.
If you could get some power into the pda you could use the bootloader to test the device. Its been years since I had my 3850.
Il have to find instructions on how to get to the bootloader but test the other things first.
Drop a comment.
Mar 11, 2008 | HP iPAQ H3835 Pocket PC
PDA would not turn on...
try to charge it for longer time, then try to turn it on, i'm not sure that its gonna work.
Jul 24, 2007 | Dell Axim X51v Pocket PC
Battery wont charge
did you think about checking the charger?
Sep 15, 2005 | Toshiba e570
HP iPAQ H4150 Pocket PC Logo
170 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
